EXIF Data does not recognise Pentax DA*60-250 SDM
Posted 15/12/2009 - 22:39
I don't think so - some of the earlier models needed a firmware update for SDM lenses (although I think that was to make them actually use the SDM rather than anything to do with EXIF). I'm not a K7 owner (or a particular expert on the technical gubbins of cameras) so I can't tell you why it's doing that, only that to the best of my knowledge it isn't because of anything you have/n't done.
Posted 15/12/2009 - 22:59
Thank you for that. I know there is a firmware update for my K7 - Not got around to uploading it, so perhaps it could be a solution:
Retired at last - now all that time for photography - you would think: wink:
Posted 15/12/2009 - 23:29
RichardDay wrote:
Probably nothing to do with the camera (firmware shouldn't affect this), but probably your imaging processing software. What program are you using?
Sometimes use Picasa for a quick resize of image or sharpen. If anything else I use CS3. Other lenses show up in the exif!
Posted 15/12/2009 - 23:39
Try downloading Photome (free) and seeing if that recognises your lens. I would think that CS3 is failing to recognise it.
K.
K.
Posted 15/12/2009 - 23:57
It's the software that hasn't updated their lens database
Does up to date (modern) software actually put details of the actual lens into the exif then?It's the software that hasn't updated their lens database
I'm using Photoshop7 and all I ever get is the focal length.
Posted 16/12/2009 - 10:37
Yes – I use Photoshop CS4 and the Camera Raw plug-in recognises all my Pentax lenses, e.g DA* 50-135mm, DA* 300mm, DFA 16-45, DFA 100mm macro. I don’t know about the newer lenses but Adobe will only update the latest version of Camera Raw. The only workaround would be to download and use the latest version of the Adobe DNG converter and convert the .PEF files to .DNG for use with the older versions of Photoshop.
Posted 16/12/2009 - 11:00
The lens ID in the EXIF is a 2-byte identifier. The PC software has to use the ID to give it a name
Posted 16/12/2009 - 11:35
"I SEE" said the blind man...
Not that it matters (for me) I can usually remember which lens I was using anyway, and if not a quick look at the exif of adjacent file numbers usually settles it.
I'll be keeping PS7 a while longer methinks
Weston-super-Mare UK
