Exif Data
Posted 01/10/2012 - 19:22
EXIF data may not be retained depending on the software used or the method in which the file is saved, for example with photoshop the exif is usually retained, however if you "save for web" then the exif is discarded.
PS: welcome to the forum.
Posted 01/10/2012 - 19:37
Also bear in mind that large images will have the EXIF Data stripped out by the forum software, to reduce the file size. If you resize to 1000 pixels on the longest side and less than 400K you should find loading will be faster and the data will be intact.
12 years
Blyth Northumberland
