Dust
Posted 29/01/2012 - 18:10 Link
Does anyone have a major problem with dust and specks on images? No matter how I clean the lens with one of those little blowers, I've set the camera to shake on start-up as well, but dust and specks always appear. It's very frustrating.
Regards,
Michael
ChrisA
Posted 29/01/2012 - 18:21 Link
Dust on the lens only very rarely becomes apparent on the image.
Are the dust specks in the same place on every image? Are they a lot more apparent at small apertures than large ones?
If so, it's on the sensor, not the lens.
You have three choices:
- Blower (just tends to move dust around, except with very large lumps)
- Arctic Butterfly (search for it - expensive, but good for dust that isn't stuck)
- Wet clean (swabs and fluid - sounds scary but isn't.)
There are lots of threads giving excellent advice on this one on this forum.
Edited by ChrisA: 29/01/2012 - 18:21
Posted 29/01/2012 - 18:25 Link
its strange as I have shots where dust is present but then on the next they are not, even when taking shots of sky etc and I haven't changed the lens. I've been out all day today and 90% of my shots are cream crackered
Regards,
Michael
ChrisA
Posted 29/01/2012 - 18:31 Link
Post a couple so that we can have a look.
As I say, sensor dust is a lot more obvious at small apertures. And on plain backgrounds.
Edited by ChrisA: 29/01/2012 - 18:32
Gwyn
Posted 29/01/2012 - 18:47 Link
Unless the dust spots are very extensive you can clone them out easily enough to save your photos from today.
Chris has asked a couple of pertinent questions about the nature of the dust spots, and pointed out when they are most visible.
Maybe you could post a couple of examples so we can help you further. Do read Chris's questions and come back with an answer.
Posted 29/01/2012 - 19:40 Link
How do I post an image to the forum?
Regards,
Michael
ChrisA
Posted 29/01/2012 - 20:11 Link
In anticipation of your question, I posted a link to the 'how-to' notes on exactly that in my earlier reply.
JAK
Posted 29/01/2012 - 21:36 Link
The K-5 has a 'Dust Alert' setting (in screen 4 of the Set-up menu)
Use that by pointing the camera at a blank wall and it will save a dust alert image. It's fully explained in the camera manual.
Should help prove it one way or the other.
John
Gwyn
Posted 29/01/2012 - 21:57 Link
Interestingly it has never worked for me. Dust bunnies all over photos, clearly on the sensor - I can see them with my sensor loupe - but Dust Alert doesn't .
JAK
Posted 29/01/2012 - 22:25 Link
Strange
jeeess1967
Posted 30/01/2012 - 12:57 Link
Hi, The best way i think to clean the spots is wet cleaning with swab and fluid. It really works.
Regards,
Jeeess
K-5, K-7 and K10D, Pentax 18-135 WR,18-55 WR,Pentax 28-105,Sigma 28-300, Sigma 28-80 (Macro) and Pentax 50-200 WR.
PeterMac
Posted 30/01/2012 - 16:49 Link
I thought I had dust spots on my sensor, but on closer inspection of my lens (18-55 mk2) I notice a fair amount of dust on them and there's none on the Dust Alert screen. Looks like the dust is on the 2nd element from the back of the lens. Much the same problem as Gwyn describes above.
What's the best way to clean this lens, or is it bin fodder?
Pentax K20D, Pentax 18-55mm II, Pentax M 50mm 1: 1.7, Super Paragon 1: 2.8 24mm Macro, Pentax smc DA 50-200 mm F4-5.6 ED
my flickr
buy images
ChrisA
Posted 30/01/2012 - 18:00 Link
This proves nothing. Dust on the lens does not appear as a speck on the image.
This also proves nothing. The dust alert is not guaranteed to show up sensor dust, as Gwyn has mentioned.
Take two pictures, one with each of two lenses, of featureless blue sky or cloud. At small aperture (eg F22), thus ensuring that the shadow cast by the speck of dust on the sensor is as small as possible.
Upload the pictures to your computer, and increase the contrast dramatically, thereby making the specks a lot easier to see.
If the specks are in the same places, it is sensor dust.
If you're really convinced the problem is the lens, I'll be more than happy to take it off your hands. Heck, I'll even pay the postage.
Edited by ChrisA: 30/01/2012 - 18:02
