Droplets macro tests
Posted 20/04/2012 - 10:57
The setup was kinda funny, because i don't have a tripod and i stabilized the camera with improvised stuff.
Basically i put a frying pan in the sink, pink kitchen cloth to cover the background and the sink, external flash( i had to move it around to find nice lighting) and k5 with FA 100/2.8 macro.
Kinda funny setup, but it worked great
Next in the list is to try to capture drop in the drop.
Maybe better cloth would make a better background too. And replace the frying pan with see thru lunch box.
http://bhristov.com
K-3 with FA 100/2.8 Macro, DA* 300/4 SDM, Sigma 150-500/5-6.3 APO HSM, Tamron 17-50/2.8 Di II, Sigma 17-70/2.8-4.5, DA 50/1.8, M 50/1.7 and Cobra 2X TC
Posted 20/04/2012 - 15:57
Makes the acheivement even more noteable.
How did you time the shot, ie how did you anticipate the drop, or are these the only two from 2000 (the number I'd probably have to take)
regards
Bernard
regards
Bernard
Posted 20/04/2012 - 17:00
i took probably 100-120 shots and these the only two i like that much i want to show. Maybe the count of success shots is about 5 or 10
Timing is... a bit tricky. Just stare at the water and after... well maybe the first 30 or 40 shots you'll probably get it Maybe it could be done much easier with stop watch and measure the time when the water falls exactly and put the camera in interval shooting, but i was using the built in flash to trigger the external and the battery of the camera was almost dead so the charging was lot more than the interval between the drops.
http://bhristov.com
Posted 20/04/2012 - 20:08
Very nice and sharp! I shall be trying this for the first time tomorrow
Posted 20/04/2012 - 20:14
Good shots, what f-stop used?
Posted 20/04/2012 - 20:17
FxIF Data (firefox plugin)
Camera Maker: PENTAX
Camera Model: PENTAX K-5
Lens: smc PENTAX-FA MACRO 100mm F2.8
Image Date: 2012-04-18 19:38:42 +0000
Focal Length: 100mm (35mm equivalent: 150mm)
Aperture: f/11.0
Exposure Time: 0.0056 s (1/180)
ISO equiv: 640
Exposure Bias: +2.00 EV
Metering Mode: Center Weight
Exposure: Manual
Exposure Mode: Manual
White Balance: Manual
Flash Fired: Yes (Auto, return light detected)
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
Photographer: Borislav Hristov
Copyright: Borislav Hristov bhristov.com
Software: K-5 Ver 1.13
Aperture: f/11.0
ISO equiv: 640
Exposure: Manual
Orientation: Normal
Color Space: sRGB
Posted 30/04/2012 - 04:47
That was even more annoying than previous one...
This time i was throwing coins in a transparent bowl full with water, again surrounded by kitchen cloths.
One YN-560 triggered by built-in flash, which was covered by sheet of black paper. Took me 40 or 50 coins to get the focus right
http://bhristov.com
Burgas
