Drilling M42 lenses
Posted 10/08/2009 - 19:38
When I read what you were thinking of doing to these superb Pentax lenses, I positively blanched.....drill a hole in them?
The focusing rings shouldn't be so stiff as to cause the lens to unscrew, but I have known it to happen.
Posted 10/08/2009 - 19:56
Yeah I know, the whole idea seems a bit sacrilegious! Also slightly concerned about what it will do to the resale value. So I'm not sure if I will go ahead or not. However I really like these two lenses and use them a lot, so I'd rather drill a hole than drop one on the floor while focusing
Having said that I have already scraped off a rectangle of paint on the 85 to allow focus trap, so that one is already desecrated so to speak
The focus ring on the 135 isn't stiff, it's just when it hits the end of the focus range it can unscrew the mount. I don't know why this is, it does the same thing if I switch the two adapters around. The 85 doesn't do it for some reason.
Tim
Posted 10/08/2009 - 20:26
Why not invest in a s/h istD/S, equip the body with the original Pentax K to M42 adapter (permanent) and by doing that converting your camera to superiority by using those wonderful Tak's out there. Case closed!
Drilling holes in Pentax glass.......brrrrrrr
Martin.
Martin.
Posted 10/08/2009 - 20:38
I'm in the (fortunate) position of having some "spares" bodies laying around so for me I:
a) Attached M42 adapter to rear of lens (nice and tight).
b) Attached assembly to a spare camera mount.
c) Using the locking-pin hole on the mount as a positional guide drilled a shallow (1-2mm) hole in the back of the lens with a 1.5mm drill bit in a pin vice (I wouldn't use power tools for this one).
Remove the mount and the job's done - simple!
Joining the Q
Posted 11/08/2009 - 08:38
Using an old mount is a brilliant idea hefty, thanks! I have an old SL body somewhere which came with a lens, but I guess it's screw mount - need to have a look. I've also found an old post which mentions putting white paint (tippex actually) onto the end of the locking pin and using that to mark the exact spot, which sounds like a workable idea but I'm a bit worried about paint on my K100ds mount.
When you say you wouldn't use power tools were you using an electric hand drill? Or a hand-powered one?
Tim
Posted 11/08/2009 - 11:15
Not a drill at all, just a pin vice (which is sort of like a very small hand drill).When you say you wouldn't use power tools were you using an electric hand drill? Or a hand-powered one?
One thing I didn't mention (but should have) is to cover the rear element with masking tape or similar before you start drilling - don't want all those metal shavings falling on the glass and scratching it!
Joining the Q
Posted 11/08/2009 - 12:09
Nice! Never knew pin vices existed, but have ordered one now. Thanks!
Tim
Posted 11/08/2009 - 12:43
I just use a Dremel with a diamond bit to make a factory looking notch. I then have a marker that matches the color of the lens, to blacken the notch.
Posted 11/08/2009 - 15:11
Make sure it's the right size! The standard ones usually hold drill bits in the range of: 0-0.8mm / 0.8-1.3mm / 1.3-3mm / 3-4.5mmNice! Never knew pin vices existed, but have ordered one now. Thanks!
As you'll be using a 1.5mm drill bit you'll be wanting a size 3 (although a lot of places sell them as sets of four so you get one of each, or pairs of double-ended ones).
For most jobs I use power tools but when there's a degree of precision involved you can't beat a hand tool for "feel" IMO.
Joining the Q
Posted 11/08/2009 - 23:36
Thanks, I got a set of four, so hopefully will be okay
Tim
Posted 29/08/2009 - 20:28
An update for posterity! I took the plunge last week and am very pleased with the results. It's great not having to worry about dropping the 135/2.5
Some tidbits for anyone else trying this:
The £3 ebay pin vice set was really crap, it would constantly lose it's grip after a minute or so of drilling. The £3 set of drill bits was also rubbish and lost it's sharp edge after about 5 seconds of drilling. However both items lasted well enough to do the job, and it's unlikely I'll ever use them again.
Each hole took about 5 minutes to drill. It was easy, but my right thumb ached a bit afterward.
I didn't have any Tippex handy, so I used nail polish to mark the end of the locking pin and make a mark on the lens. This took a couple of attempts to get a visible mark.
Black indelible marker works reasonably well for making the shiny silver hole less obvious after you've drilled it.
No idea what this does to resale value. I imagine it kills it for collectors, but I suppose it might not hurt too much for people interested in actually using the lenses on dSLRs. Neither lens was in mint cosmetic condition anyway, and the 85 in particular shows a lot of brassing.
The silver rectangles to the left of the drill holes are where I've scraped the black paint off with a penknife to allow focus trapping. I know they're ugly
The 85/1.8 (initial hole was about 1mm too close to the adapter, hence the slightly elongated hole ):
The 135/2.5 (perfected the nail polish technique by now ):
Tim
Posted 29/08/2009 - 21:12
would have been a lot easier to just use some thread locking adhesive like Loctite, and it wouldn't do any damage to the lens.
Posted 30/08/2009 - 09:55
Eh? I think you might have misunderstood the original post It wasn't the screw mount adapter coming loose.
Tim
Posted 30/08/2009 - 11:05
(Tried to edit the previous post but the time has expired or something)
To clarify for Yves, it was the K-mount bayonet which was unscrewing, so the locking pin hole solves this. The adapter doesn't unscrew.
Tim
Saffron Walden,
Essex
Any tips on how to clamp the lens, am I likely to crack anything? I am considering doing this to my Super Tak 85/1.8 and 135/2.5. The 135 in particular sometimes partially unscrews when I fully rotate the focus ring.
Thanks!
PS I'm using each of these with an infinity-focus M42-PK adapter which is left permanently on the lens.
