DP review looks at KM
Tony-O
Posted 31/01/2009 - 09:36 Link
Worth a read.Also the girls portrait, in images, is taken with the new SDM 55mm 1.4.So there are one or two flying around.T.
K7,DA*50-135, 35mmLTD Macro, 21mm Ltd, Voightlaender 58mm 1.4 NOKTON SL,Ricoh GRD,GRX, Zeiss 100mm f2 Makro Planar.Zeiss Ikon ZM,Zeiss f1.5 C Sonnar.
It ain't no sin to take off your skin,and dance around in your bones.Tom Waits.
Daniel Bridge
Posted 31/01/2009 - 10:59 Link
Apparently the 55mm lenses that are about at the moment are pre-production ones, so perhaps not trull representative of the production version, but I still want to have a play with one.
Dan
Anvh
Posted 31/01/2009 - 16:39 Link
I'm reading it now but what is a Power Lamp???
it's on page 10 of the review and it has the settings:
1: Std
2: Weak
3: Off
is it just the simple lamp that's on when the power is on?
Stefan
K10D, K5
AF-540FGZ
GlynM
Posted 31/01/2009 - 20:32 Link
... is it just the simple lamp that's on when the power is on?
I think so. A quick look at the down-loaded manual shows that the power light is just behind the on/off switch. It is a sort of rectangle with rounded corners. You can see it in the review pictures.
I'm assuming that the power light is necessary because there is no LCD panel on the top of the camera.
The manual does not seem to say why you might want to dim the power light but I guess it is to help battery performance and possibly to stop it being annoying in the dark.
Glyn
Anvh
Posted 31/01/2009 - 21:51 Link
Thanks for the answer Glyn.
I always forget to put out my camera even if it have a top lcd, luckely it has a standby mode
Stefan
K10D, K5
AF-540FGZ
