Do I meed a K5 ?
Posted 06/08/2011 - 13:58
The K-r operates just the same way as the K-x, but is faster and has focus point indication in the viewfinder. It's a lovely camera and will slide seamlessly into your existing style.
Only buy the K-5 if you need weather resistance or the higher pixel count or the better low light performance. Bear in mind you may not have any WR lenses though.
Posted 06/08/2011 - 14:06
I have a K-x and have upgraded to the K-5. It has obvious advantages such as weather sealing and faster AF which have benefited my wildlife/bird photography. ISO performance hasn't blown me away, as the K-x is very good in that dept anyway.
So, it depends very much on what you photograph, and what you want to photograph moving forward.
Posted 06/08/2011 - 15:17
I'd rather get the K-r and another lens for the price difference on the K5.
Posted 06/08/2011 - 16:49
Good point on the lens front.. I also like to photograph wildlife, and have found the autofocus a little unrealialbe on the kx. I also think £500 extra just to get weatherproofing. Would not excite me. I was wondering if there had been a distinct improvement in picture quality, since the upgrade. Bearing in mind to have kept the same glass..
Stuart..
Stuart..
Posted 06/08/2011 - 17:37
It isn't just weatherproof though, you also get a magnesium body, brighter and better viewfinder, slightly better AF, 2 e-dails (more advance controls).
If you were happy with the Kx and don't need more then get the Kr but if you want more controll, then the K5 is the one to get.
Because i mostly shoot in manual i can't think about losing one of the e-dails
ps. isn't the SR also more advance with the K5 or not?
Posted 06/08/2011 - 23:17
you may need a spill chucker
I didn't know you were a New Zealander, Mr Everitt?you may need a spill chucker
I'd go with the K-r, if you're fairly new to photography. Take a million photos with it, and when you're just starting to feel comfortable with it, go and get yourself a K5, or K3 or whatever the top spec is at the time. That's how you learn, by jumping into deeper water and forcing yourself to adapt to challenges. I'm signing up for Rocket Science at the local tech college next week....
Sam-Joseph
Pentax K7, Sigma 17-70 f2.8-4.5, Sigma 70-200 f2.8 APO EX, Sigma 70-300 APO, Sigma 1.4x TC, Vivitar 2x TC. Takumar 135mm f2.5, SMC Pentax A 50mm 1:1.7, SMC Pentax -M 1:4 200mm, Pentax X70
What were the limitations you ran into that the K5 could solve?
Can you work around them or otherwise live with them?
Well, then there's your answer.
Posted 07/08/2011 - 02:07
What Stefan says!!! It isn't just weatherproof though, you also get a magnesium body, brighter and better viewfinder, slightly better AF, 2 e-dails (more advance controls).
Manchester
Stuart..
