DENOISE
Posted 23/01/2016 - 16:07
I am undecided about it. I do not have LR so I can not compare. The interface seems quite complex with different ways of working and I suspect one has to be familiar with the detailed functions to get the best out of it. It seems to be at least as good as the other denoising programs I have tried, but I am as yet sure whether it would be worth getting it.
Miles
Posted 23/01/2016 - 18:51
Thanks Miles - yes the interface does look quite complicated, but also looks like if you know what you are doing then you should be able to apply different settings for different situations. I am undecided as well - having wasted money on other programmes over the years that don't live up to expectations...
Andy
Posted 23/01/2016 - 20:21
I got denoise few years back and got so used to using it that I never really bothered denoising anything in LR, so I can't compare; however, I find the interface really user friendly. It's not complicated at all. The base presets are not necessarily perfect, but they are a good starting point for your own adjustments which cuts the time needed to modify a pic. One thing I do like is the add grain option. Not sure if you can do that in LR easily. All in all - I enjoy using it but to be frank, if you are happy denoising in LR, I'm not so sure this is some sort of a miracle replacement
Posted 23/01/2016 - 22:57
Hi Magdalena - is this the same denoise as the one on offer - see Latest Posts?
Andy
Posted 24/01/2016 - 08:03
Hmm...can't spot the LAtest Posts regarding the offer. I just assumed it's Topaz Labs as that's what their plugin is called. If someone else is using the same name I'm not aware, sorry. To be honest, I would not buy it just in spite in that case haha. Hate it when people try to use other's good rep to make money with less effort....
Posted 24/01/2016 - 08:16
Cast your eyes to the right of your last comment and you'll see the offer under Latest Posts.
Posted 24/01/2016 - 08:36
Aha! Nice one John, thank you. Surprisingly blind for someone that likes to run around with a camera In that case, no; that is not the software I had in mind. I know nothing about it, sorry.
Posted 24/02/2016 - 11:33
How do you get the software offer as when I tried it was still 97 pounds
21 years
North Devon
