Decent underwater housing
Posted 16/07/2011 - 20:09
In case anyone's interested, I found a link to a seatool prototype housing for the K-5 and K-7.
Here it is. If the pricing is the same as the Kx housing, it's about £1800.
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Posted 16/07/2011 - 20:20
I think that there are a number of off the shelf underwater cameras that do a fine job for less than the price of an underwater housing, and the shooting environment negates any advantages you might find between your trust k5 and a lessor camera.
I use a Go-Pro for that kind of shooting....
Posted 16/07/2011 - 23:34
If you mean the little silver cameras which can do HD video or stills and come with a waterproof housing then they're ace. My brother bought one with the "Motorsport Hero" package a while ago to hang on the outside of various cars, has yet to fall off and produces top quality footage. I use a Go-Pro for that kind of shooting....
Cost? £300 with the motorsport pack, a little less if you have the camera alone without the extra mounting parts to fit it to windscreens/panels. Much safer bet than risking your DSLR (and smaller too).
Posted 17/07/2011 - 00:08
I saved even more money by going with hd 960 hero... when converted into apple prores, the footage fits in just fine with higher res files from other cameras... also.. the little plastic box it comes in? do not toss that away.. the black box lid has a mount built in and with a little green or blue painters masking tape can be mounted onto autos really easy....Don wrote:
here's mine with my servo pan tilt head and remote viewing through camcorder set up:
and my car chase scene rig:
and a video:
link
and yes the above images taken with a pentax and the stills in the movie also on a pentax...
Posted 17/07/2011 - 01:15
geclinke wrote:
Not sure if anyone's interested, but I noticed on some forums that Ikelite are considering making an underwater housing for the K5 / K7.
I'm sure anyone who already owns an Ikelite housing knows how good they are so it's worth contacting them to register your interest.
Obviously it's not going to be cheap, probably around £2K. But even if the tooling costs £20K, it doesn't take many sales for it to be worth their while.
With the K5 low light performance and small size, I think it could be an excellent proposition for underwater photography (and my Ewa Marine "bag" is getting a bit long in the tooth).
Well I hope SRS can get one to hire out, cos that's way too expensive, but hiring may make sense. However I can see why you'd want to use your k5 if you have a passion for underwater photography. A couple of metres down and it's already a lot darker than the surface.
Posted 17/07/2011 - 05:49
I thought Ikelite had actually replied to a few enquiries recently (plus the 2009 post below) and said that they had no plans to build one since they had no free time on their production for testing - business is good it seems.
I put the post below up on another forum :
You have options :
Customized housings designed by SPL Waterhousings in collaboration with Pentax Imaging USA. SPL is the only custom housing maker that makes specialty products for the Pentax line of SLRs.
SPL Water Housings - Custom crafting splash housings since 1996 - SPLwaterhousings.com
SPL Underwater Housing for K7
____________
This from Ned Bunnell - President of Pentax in N.A. :-
Ned Bunnell , Sep 30, 2009; 09:19 p.m.
David,
Mark's housing is made by SPL Waterhousing in San Diego (SPL Water Housings - Custom crafting splash housings since 1996 - SPLwaterhousings.com). I had a chance to visit their facility, as we provided SPL originally with a K10D body so they could build the first housing which Mark started to work with. SPL builds quality housings ideal for surfing and on water photography. I have not talked to the folks at SPL in several years, but depending how many controls (buttons) you want access to and the number of lens domes you'll need, I believe their housings start at around $1200-1400. Hope this helps.
Regards,
Ned Bunnell
Glad to find out who the other person using this housing is. I am a photographer based in Tofino on Vancouver Island and just ordered the housing for the K-7. I was packing my camera up for the long trip down to San Diego when he told me that he was fortunate enough to already have a body for molding purposes, Thanks Mark. For the housing with the 10-17 port it came to $1699.00. Not bad for a custom made housing.
___________________
June 29th, 2009 10:44 AM #2
Ikelite Staff
Equipment Manufacturer
In the past we haven't seen enough customer demand for the support Pentax dSLR cameras for us to invest in the development of a new housing. We do keep an eye on new models from all manufacturers however.
So the best answer is that I don't expect us to offer a housing for it. However that could change if there seems to be a significant increase in demand over previous models.
Regards,
Jean / Ikelite
IKELITE Underwater Systems
____________________________
Opteka Housing (similar to EWA) :-
Opteka Underwater Case/Housing for Pentax K7 KX K1000 | Underwater Camera Deals
And Diveross make housings for the K5, K7 (both DRP100) K20, K10 (both DRP 200).
DRP100 DIVEROSS - PHOTO- Diveross underwater tecnology, photo and video housing | Plastmeccanica s.r.l
Prices for the Diveross DRP100:
Housing with standard port: € 799
Housing with spherical port: € 899
Standard port separately: € 119
Delivery within three weeks after placing the order.
You have options :
____________
David,
Regards,
Ned Bunnell
___________________
Ikelite Staff
Regards,
Jean / Ikelite
Posted 17/07/2011 - 18:35
I did take a look at the SPL housing, but's it's more of a surface product than a dive product - e.g. fine for splashing about at the surface but won't go much deeper than 5m.
It's good that Seatool are producing a housing, but availability outside Japan isn't great anyway - not even sure they have an official UK distributor.
The diveross housing looks interesting, but I can't see any reviews for it anywhere. Plus, I don't trust the "one size fits all" approach that the product seems to take. I'd want to see it in action to see whether it can actually reach all of the camera functons.
Posted 17/07/2011 - 18:45
I actually doubt it will, and even if it did you can't reach the most important ones; the scroll wheels i beleive.I'd want to see it in action to see whether it can actually reach all of the camera functons.
So you must shoot in auto mode if you like it or not.
Posted 24/10/2011 - 21:04
Woohoo, not sure if anyone else posted this, but it's here and cheaper than expected;
http://www.ikelite.com/web_two/pen_k5.html
Shame it wasn't out a few weeks earlier or I would have bought one.
London,
UK
