da* 50-135 sticky focusing
BarMac
Posted 29/01/2009 - 21:54 Link
My da* 50-135 suffers sluggish focusing especially in cold weather. It is generally slower than my old screw drive lenses and sometimes refuses to focus at all. Unfortunately its now out of guarantee. Can anyone recommend a good repairer? Incidentally, this is the best of my Pentax lens collection and is pixel-sharp corner to corner from f5.6
petercf
Posted 29/01/2009 - 21:57 Link
Do you have another SDM and does it perform the same?
Digital: K20D+D-BG2 Grip, K10D+D-BG2 Grip, DA* 300 F4, DA* 50-135 F2.8, DA* 16-50 F2.8, DA 17-70 F4, DA 50-200, FA 100-300, AF540FGZ, F Remote release
Analogue: KM, 200mm M,135mm M, K 2x Conv, 28-80mm A, 55mm M, 28mm M, Vivitar 283
Other: Sony PC Digicam,2x Conv,0.7x Sea&Sea wide conv,Sea&Sea Underwater housing, GreenForce 2 x 50W HID lights + double capacity battery, Fujitsu F31 and Underwater housing, Nikon 7900+Underwater Housing
BarMac
Posted 29/01/2009 - 22:11 Link
Hi Petercf - yes a Sigma 10-20 which is fine. To answer your implied question I do think its a lens fault and not a camera fault. The problem is quite variable and mechanical rather than electronic in nature.
Anvh
Posted 29/01/2009 - 22:12 Link
I don't believe these things are repaired in the shop but are sent off to Pentax, don't know if that's true but I believe they do so.
You can take it to the shop and see which is the faulty one, the camera or the lens.
Stefan
K10D, K5
AF-540FGZ
petercf
Posted 29/01/2009 - 22:13 Link
Umm - is the battery fully charged each and everytime?
Gwyn
Posted 29/01/2009 - 22:31 Link
The Sigma 10-20 doesn't have HSM in Pentax mount!
Oggy
Posted 29/01/2009 - 22:32 Link
Now I am depressed.
I have been a member of the DA*50-135 owners club for about 12 hours now (having found no negative feedback on them anywhere).
I have two in-lens focus motor lenses, the 50-135 and a Sigma 150-500, and I was surprised to find that the Sigma seems faster to focus and quieter than the Pentax so far.
fatspider
Posted 29/01/2009 - 23:15 Link
Barrie, was it bought in the UK? and how old is it?
Under UK law if your willing to argue your statutory rights you may get the lens fixed free of charge. goods must be fit for the purpose they are sold and as a consumer you can expect a £400+ lens to last a lot longer than 12 months, if it does'nt it is not fit for the purpose it was sold.
Did you ever wonder why that after you've read a product comes with a 12month warranty there is smallprint underneath that says "this does not affect your statutory rights"
My PPG link
My Flckr link
BarMac
Posted 30/01/2009 - 11:33 Link
Well spotted, of course it doesn't.
On the other points, yes the battery is charged, yes the firmware has been updated and yes the lens was bought in UK so I'll see if the shop can help.
I can reassure Oggy that otherwise my 50-135 is a very fine lens.
Interestingly, I also thought the da*16-50 (which I tried but didn't buy) was rather sluggish focusing.
Gwyn
Posted 30/01/2009 - 12:10 Link
Is there maybe another Pentax User member in your area with an SDM lens and a K10D/20D who you can meet up with maybe, just to try it our on another camera and to try another SDM lens on your camera? How far is Impotentspider in Leeds from you for instance? You could try contacting someone by PM.
Otherwise I would contact the shop you bought it from or Pentax UK and talk to them about it - as Spider says you have more rights than just the 12 months guarantee.
Unlocker
Posted 30/01/2009 - 16:48 Link
Mine is doing the same thing, sometimes it just won't focus at all. Just tried it now, took about 10 seconds or so to lock on the 1st time, as if it was 'stuck' a bit, then it was OK apart from a squeak.
Will be taking it back to SRS at some point to get it sorted, but whilst it is usable, with a honeymoon 3 weeks away (!), I can put up with it till then.
As spider says, fit for purpose is very important, and people just don't know they can use that when 12 month warranties are up. However, did you buy it from a Pentax Pro centre? If you did, it's 2 years warranty anyway so you're covered. Bought mine from SRS so I'll be fine anyway, any problems anywhere else I just go into the Sale of Goods Act 1974 speech!
Oggy
Posted 30/01/2009 - 22:07 Link
womble
Posted 31/01/2009 - 00:24 Link
I sometimes find with mine that it won't focus if it is a long way off but a slight manual nudge and it kicks in OK.
It has never been much (any?) faster at focusing than my screw-drive lenses but it is almost silent.
Best wishes, Kris.
mille19
Posted 02/02/2009 - 12:22 Link
I've had this 'sticky focussing' problem with my DA* 300mm, it was also in cold weather.
Oggy
Posted 02/02/2009 - 17:22 Link
I gave mine a soak test at 6degC yesterday, gave up when the snow started.
No problems.
