Cropping
Posted 02/07/2026 - 15:58
I prefer to get the image I want in-camera, coming from a film SLR background which began nearly 60 years ago. I even still use colored filters for monochrome photography (I own 12 of them, which can be used on either of my most-used lenses). However, there are still times when I use Photoshop for what I consider relatively minor changes to an image, such as cropping. Even back in the day, when I developed and printed Tri-X and Plus-X film, I took advantage of the darkroom. I would alter the brightness and contrast of prints, crop, and dodge, to get the prints I wanted.
Dale H. Cook, Pentax K-70, Pentax DA 35mm, Pentax-D FA Macro 100mm, Pentax-DA 12-24mm,
Pentax DA 18-270mm; Mamiya/Sekor 400mm; Rokinon 650Z 650-1300mm
https://plymouthcolony.net/photos/index.html
Posted 02/07/2026 - 18:34
Anyone else doing this as a matter of course or are most better at seeing the shot they wanted from the outset?
Well....
"I think this mostly comes down to personal preferences combined with subject matter " to quote your kind self. but seriously I also am from the film days and so try to get it right first time but see nothing wrong in cropping, another luxury of digital.
Well....
Posted 02/07/2026 - 19:02
I like this Lenny and prefer the Crop here ,I crop sometimes to get what looks best to me in my landscape photos as far as Birds etc I always crop 🙂
I do like that lens Paul
Posted 02/07/2026 - 22:32
For me, getting it right in camera is a luxury that is possible only when there is plenty of time available - which there usually isn't. Tripod, get the framing right, wait for the clouds to shift a bit... those were the days! But circumstances have changed. Now it's usually a matter of getting it as close as reasonably possible in camera but allowing space to crop later. And taking several versions and choosing the best later. Macro, though, is a different matter entirely, particularly if doing a focus stack. Cropping just means wasted pixels when the idea is to get as much detail as possible. I will, however, crop to square or another format simply because the sensor I have to use is 3:2.
Posted 03/07/2026 - 15:37
The start of an interesting thread. I'll be interested in where it goes. I agree with LennyBloke about the K1 and the 21mm lens. My favourite combo.
Posted 03/07/2026 - 16:26
Lubbyman wrote:
For me, getting it right in camera is a luxury that is possible only when there is plenty of time available ...
For me there is normally plenty of time available. Old water-powered mills don't move, and aren't going anywhere. Nowadays photographing mills in a new area is generally a 2-3 day affair. First I have to visit each mill, and photograph it from a few angles to determine the ideal composition. Sometimes that requires using a long lens to get my preferred view. When that is done for all of the mills which I am visiting I need to determine which view to use. Because that view is not always optimally lit, I use the compass bearing in my camera's GPS and a computer utility to determine a window of optimum sunlight for each mill. I can then go back and get the final photo of each mill. I am still re-photographing mills which I first visited before I bought the Pentax O-GPS2. For those I use Google satellite view to determine the bearing of a photo close enough to use the utility.
Posted 04/07/2026 - 13:47
As much of my photography is undertaken while under the supervision of a large German Shepherd I too find that time is a luxury. Agree with others on here that most of my bird / wildlife photography does involve cropping. I still try with less nimble subjects to get the composition right in camera (or as near as possible to reduce cropping).
Stephen
Flickr Page
Photocrowd Page
Flickr Page
Photocrowd Page
Posted 04/07/2026 - 16:49
SSF1957 wrote:
Stephen
As much of my photography is undertaken while under the supervision of a large German Shepherd I too find that time is a luxury.For me, getting it right in camera is a luxury that is possible only when there is plenty of time available - which there usually isn't.
Stephen
Posted 05/07/2026 - 19:58
It seems we all mostly try to get it right at the time of shooting - but with with the larger MP sensors in particular we really do get a second chance to create a good image if the first doesn't look quite right. The first time this really hit me was on a trip to Venice - the city is such a photographers playground that there are so many views to create good images from, with many of the building shots I found I could use the GR to just snap and then make the final image after viewing the results back at home on the bigger screen.
Posted 07/08/2026 - 17:41
Personally, I hate converging verticals on photos of buildings. I have a shift lens to solve that problem and with the in-viewfinder levels of the K-3iii I can even hand hold it, although its far better on a tripod. Often, however, I don't have the luxury of fitting the lens and faffing around so I have taken to getting the image square using the levels and then cropping heavily to get rid of the masses of unneeded foreground. Given that 99% of my photos rarely get used for anything other than viewing on a screen or a data projector, the loss of resolution is neither here nor there. If I really need a high resolution photo of a building, I'll wheel out the Horseman 5x4.
Posted 07/08/2026 - 20:17
I'm terrible at compositions 'in the moment' so cropping is my crutch.
It's something I know I'll improve too slowly to make a big difference so I sit here and admire the work posted to this forum instead.
All the gear with no idea
Posted 08/08/2026 - 03:32
Agreed.
Agreed.
Worcestershire
1. Original
2. Cropped
Heavy cropping is quite common on certain subjects (aircraft, birds, wildlife, etc.) but for me changing format (portrait to landscape and vice versa) can transform an image into something I may not have envisaged at the time of shooting.
