Corby Crow
Posted 21/06/2013 - 23:36
Very difficult to get a good shot of these birds due to the black feathers! I like this shot, the only thing it needs is the shadow detail bringing out so the feathers can be seen.
Posted 21/06/2013 - 23:52
Barrie - Too Old To Die Young
Posted 21/06/2013 - 23:59
Yes Barrie, that's exactly what I had in mind and you have done an excellent job with it!
Posted 22/06/2013 - 01:02
Posted 22/06/2013 - 08:11
bforbes wrote:
I hope this is what David had in mind
Shadows and highlights adjustments in Elements 11
It just looks over exposed.I hope this is what David had in mind
Do what you did to that version with the bird only, but leave the background as per the original.
Posted 22/06/2013 - 09:57
Smeggypants wrote:
[quote:3496ace15f="bforbes"]
I'm not that much of an expert. Any lessons going Smeggy
Posted 22/06/2013 - 10:05
It depends on the software you're using Barrie, but there is usually an option to bring up the shadows and control this by varying the range of tones that you apply the adjustment to. This way you can restrict the changes to the darker areas only.
The other way is to work in layers and only change the bits you want to change.
Posted 22/06/2013 - 10:27
Posted 22/06/2013 - 11:17
That's very nice Algi, and raising the bar a bit. I did flatten the highlights on mine to reduce the distracting background highlights but, looking at it, that has taken the sparkle out and I prefer yours.
Being hyper-critical: Possibly processing pushed a little far as there are some artifacts creeping in around edges - particularly around his neck.
Posted 22/06/2013 - 11:21
Posted 22/06/2013 - 11:29
Thanks for the input, I will have another play now I can see what can be brought out, as my attempts were killing the shot.
