Converting sRGB toYCbCr
aliengrove
Posted 16/06/2013 - 23:22 Link
I don't suppose we have a member here fluent in Linux, who can tell me a simple way to do this conversion, preferably with some sort of Photoshop (or more likely Gimp) action, and then to be able to convert the image back to sRGB after editing? I understand some Linux but not enough to do this. Any advice much appreciated.
Edited by aliengrove: 16/06/2013 - 23:36
gwing
Posted 16/06/2013 - 23:36 Link
Imagemagick is the generally used swiss army knife for fancy image conversions on Linux and can convert either way for you. This post here seems to give a lot of examples and workarounds for dealing with some unwanted colour shifts that can otherwise occur.
http://www.imagemagick.org/discourse-server/viewtopic.php?f=3&t=23404
And here giving examples of using this on a video stream
http://www.wizards-toolkit.org/discourse-server/viewtopic.php?f=1&t=15192
What editing program are you thinking of using that operates in YCbCr?
Edited by gwing: 16/06/2013 - 23:41
aliengrove
Posted 16/06/2013 - 23:48 Link
I've had a look at Imagemagick but it looks pretty complicated. Basically i want to be able to convert an sRGB file from my K5 to YcbCr, and then replace the luminance channel with the one from an infrared file. I also want to try replacing the luminance channel in a 665nm image with one from an 830nm image.
Gimp can edit YCbCr images, but I can't find any conversion tool available to convert the images in Gimp.
Edited by aliengrove: 16/06/2013 - 23:55
gwing
Posted 17/06/2013 - 00:23 Link
Yes Imagemagick certainly is complicated - that's so it can manage to accomodate folks with obscure requirements like yours
This really isn't anything I have tried myself, but there is a colour decompose plugin for Gimp that will separate out the luminance and Y channels and maybe be what you are looking for?
aliengrove
Posted 17/06/2013 - 00:40 Link
Thanks very much for that, I've just been looking at the plugin. I'll give it a try. It looks like it could be be useful for what I'm trying to do, which is basically to get the detail of IR and the colour of a normal shot in the same image. I've had some success with blending images using CMYK, but can't get the colours quite right.
Edited by aliengrove: 17/06/2013 - 00:43
aliengrove
Posted 17/06/2013 - 11:11 Link
Just downloaded that plugin, and it can decompose to YCbCr, just what I needed, I'll try it out!
