Converters for a DA 55-300
Technoblurb
Posted 03/02/2010 - 18:07 Link
I was wondering if it is possible to get 2x or any converters for a DA55-300 and if available is it worth it?
Mike-P
Posted 03/02/2010 - 18:32 Link
I tried a few when I had the 55-300mm and wouldn't recommend any of them. Although a good lens in its own right I found it just too slow with a teleconverter and the IQ suffered quite a bit.
Technoblurb
Posted 03/02/2010 - 18:41 Link
Thanks Mike, Maybe I had better keep an eye out for a Bigma
Hyram
Posted 03/02/2010 - 18:43 Link
You can still buy the Pentax 2X-S but bear in mind that you will have to manually focus.
Hyram
Technoblurb
Posted 03/02/2010 - 18:45 Link
Have you ever used one Hyram, is the result worth the cash.
iceblinker
Posted 03/02/2010 - 18:52 Link
Kenko 1.5X isn't too bad with a Tamron 70-300mm, and even the auto focus works. Same should apply to the Pentax 55-300mm.
2X would be pushing it, though, in terms of practicality as well as image quality.
~Pete
JonSchick
Posted 03/02/2010 - 19:03 Link
I have a Kenko MC7 which I think is quite good, but in reality I suspect there is little difference between using it on a high resolution camera and cropping the images taken without.
It may be more useful on 6 or 10MP cameras, but cropping with the newer bodies may be able to outperform the TC.
In addition, given the 55-300 is not exactly the fastest to focus at longer lengths, I wonder whether a TC might make it slower than many people would like to live with.
Jon
Some occasional random stuff at The Photographers Block: link
RichardDay
Posted 04/02/2010 - 11:25 Link
I'll endorse Mike-P's view. Just not worth it. I had the Tamron 1.4x TC, generally reckoned to be about the best of them, which I tried with my 55-300. The IQ results were unimpressive, definitely better to crop, plus the AF speed was painful.
If you definitely need a long telephoto, then the most affordable solution with decent AF is the Sigma 150-500. I have tested it against the DA*60-250 cropped by 2x from 14MP K20D shots and it holds up very well, the DA* is slightly better at reasonable print sizes but beyond A4 the Sigma wins.
I have recently added a (now very rare) Promaster 1.7x PzAF TC that works with the 60-250's SDM on the K20D and it is probably worse than the Sigma 150-500 which is almost half the price of the 60-250 plus the TC, but the Sigma is a very large lump of a lens. I have some test shots with the TC and 60-250 here - Promaster 1.7x tests
There really is no cheap solution to even half decent very long zoom lenses with acceptable handling and performance, the Sigma 150-500 is the most affordable. Start saving!
Richard Day
Profile - link - (click on About for equipment profile) - My Flickr site - link
Hyram
Posted 04/02/2010 - 11:46 Link
I have one but have not used it, as yet.
All the Pentax TC's are highly regarded.
I will buy the SDM version if Pentax ever produce it
I would also buy a longer prime than the DA* 300 but again Pentax needs to produce one
Hyram
Technoblurb
Posted 04/02/2010 - 11:58 Link
Thanks everyone, this has been very informative and has saved me wasting cash. The converters would have been nice due to the reduced weight and cost. Like Richard stated, I had better get saving.
Graham
Hyram
Posted 04/02/2010 - 12:07 Link
There is of course that FA* 600 for sale
Hyram
Technoblurb
Posted 04/02/2010 - 12:27 Link
I broke the bank purchasing my Da16-45 & DA 55-300 no stars attached, to purchase the FA* 600, any donations greatly received
iceblinker
Posted 04/02/2010 - 16:12 Link
I generally agree with that, except when noise is high when using high ISO. Then some slight softness from a good converter can look better than magnified noise from cropping, in my umble onion.
~Pete
Edited by iceblinker: 04/02/2010 - 16:13
RichardDay
Posted 05/02/2010 - 17:59 Link
Correct, but a decent NR program like Neat Image or Noiseware Pro can make a reasonable improvement. I generally find that producing a completely unsharpened and no NR image from Silkypix Pro and using either of the above NR programs usually produces the best result with higher ISO (above ISO 800) shots from the K20D or K-7.
Richard Day
RichardDay
Posted 05/02/2010 - 18:14 Link
Graham
SRS have 150-500's at a low(ish) price at the moment. May be worthwhile, but remember to book some muscle building sessions at the gym as well!
Richard Day
