Control wheels and grip
Posted 03/04/2009 - 00:21
Sometimes one of the wheels, either grip or body, doesn't quite click all the way to the next notch, so it doesn't register properly. Just make sure when turning the wheels that they register a click firmly as if you leave it halfway between 2 clicks it does confuse the camera.
Hope that makes sense!
South Lanarkshire,
Scotland.
I have read of similar problems in this forum, and, using their advice, I turned the camera off removed the batteries for a bit and refitted them. On turning the camera on again, still the same problem. I then turn off the battery grip and found that all the control wheels on the camera body worked normally again!
Has anyone else experienced this problem?
