Continuous vs Flash Lighting and Everything in Between - Part 7
Photograph titled 'Another from Horsey Gap' by markm selected as Pentax User's Photo of the Week.
Photograph titled 'Faithful' by rex1999 selected as Pentax User's Photo of the Week.
Paris,
France
In Part 6
I stated that I would discuss a more complex set up of the same setting. When using your standard flash head, i.e. (those that usually are fixed to the hot shoe), they never come with a pilot or modeling light. What I suggest you consider here is placing a 60-100 watt light bulb directly above or below your flash unit to mirror the direction of the flash you will be using. What I also suggest is that you frame that pilot light in the same manner as you did with your flash. For example if you built a "Snoot" for your flash our of an elongated tin can you could mirror that on on your pilot light. The ideal situation would be to place your flash slightly behind the pilot light bulb and share the same snoot. This would then cast only one shadow. However, as the light bulb can be very hot, this must cause damage to the flash unit. You might consider using cold lamps that generate very little heat by comparison, thus allowing you to apply this configuration.
I would like to introduce another element that can be used quite creatively and that is what is called "Barn Doors". "Barn Doors" look just like what you might think and that is two small perhaps black cardboard or metal rectangular shaped modifiers around 6-9 inches wide by 8-12 inches long that frame the flash or tungsten light unit allowing you to frame the light coming of of your lighting source. The more you close these barn doors the tighter the light becomes on the subject you are lighting. It is ideal that you find a way to pivot these panels. This will make it a lot easier to manipulate. You can add two more barn doors horizontally, allowing you to create a horizontal and vertical window of light. You may wish to use several of these units to create some very interesting lighting landscape in your composition. If the light is too harsh, you may also add a diffuser to soften the light coming from your source.
I hope you have found this mini series helpful and hope it gave you the inspiration to experiment and to break with convention. When it comes to lighting, the sky is the limit.
In Part 8, I will discuss a totally new lighting set up.
http://www.benjaminkanarekblog.com/?p=652
http://www.benjaminkanarek.com
http://www.pbase.com/benjikan/publishedworks
