Composing your shot using manual lens
Posted 20/09/2014 - 10:39
I use centre focus with all lenses, half pressing and recomposing.
And I use live view with digital zoom and focus peaking if manually focussing and the subject is static.
Posted 20/09/2014 - 23:36
Posted 21/09/2014 - 00:11
It depends what you are meaning by a manual lens. Manual focus? Manual stop down?
Let's take manual focus, where it really is just a matter of turning the focusing ring until the image is sharp in the viewfinder. What part of the image is up to the photographer.
To make focusing easier, make sure the dioptre correction is set up. Look at a blank wall or sky and turn the dioptre adjustment until the etched lines in the viewfinder are sharpest. That will adjust the viewfinder for your eyesight.
Posted 21/09/2014 - 08:11
Agreed John, there really is no 'centre focus' for manual lenses. By being a manual lenses, there is no ability for the camera to automatically adjust the focus itself. From memory adjusting the dioptre without a lens attached works also.
The Pentax (on suitable models) will give a focus confirmation when something is in focus, and this shows you were it's detected this, as you adjust the manual focus ring. This is limited to where the autofocus sensor points are though I suspect.
Posted 21/09/2014 - 09:43
I thought with a manual focus lens that ONLY the centre focus indicator worked at all? And i suspect that the focus hexagon only works when focus is achieved at the centre also ...
Our OP mentioned focus and recomposing holding the button, but in fact this is only applicable to autofocus ... Half pressing the shutter with manual focus (with an old lens or an af lens set to manual) will only activate the focus indicators, which will light when something in the centre is in focus ... The lens cannot'lock' focus as such.
In my experience it can be problematic focussing on the centre then recomposing with manual focus lenses, as something off from centre is rarely on the same plane and angle, so you lose sharpness slightly ... Better to use the techniques already described here by the others. Any way that magnifies the required point of focus so it can be' eyeballed' it's going to be most accurate.
Posted 21/09/2014 - 10:17
Thank you Nigel....
You've just confirmed my thoughts on the matter .
Very much appreciated
A hungover .....
Sean
A hungover .....
Sean
Sean
Sean
Posted 21/09/2014 - 11:18
I agree too, Nigel
Posted 21/09/2014 - 20:32
I often use the centre focus pint then re focus for landscape shots as I use a small aperture (as you do) and am not usually very close to the main part of the subject however, if it is a close subject I trust my eye
I love using manual lenses
Auldearn..Nairn,
Bonnie Scotland
Sean
Addicted to everything manual
Sean
