Clip on meter help
Can you verify which camera body you're attaching to?
Thanks,
Mac from Montreal
S Raff
S Raff
There are three basic models of clip on meter.
Model I has an oval dial and is intended for the S and H series models. There are variants of this type.
Model II is rectangular in shape and is also for the S and H series.
Model SL is for the Pentax SL and is a different fitting for the diffent shape of the pentaprism on this camera. This is because the SL is a Spotmatic without the built in meter. The idea of having a Spotmatic with a mater in, marketing a version without a meter and then producing an add-on meter for it seems pretty obscure to me. 1964 logic no doubt.
I can't account for the dial not fully turning. Don't force it, but check that the dial on camera and meter line up when you attach it and that everything is clicked firmly into position. Some previous owner could of course have messed it up for you.
What I expected was by adjusting the shutter speed with the meter attached to the camera the meter would then show the relevant apature. As it stands the meter shows an apature but no change when the shutter speed adjusted.
Before mounting the meter I set the ASA to match the film speed and for example 400 and that shows 1/60th on the meter dial, I set the camera to 1/60th and then they meet perfectly. Likewise a could set the meter to say 50 ASA and that gives me a 1/8th reading, set the on the camera and again the meet perfectly. Turn the meter to the relevant H L setting and the dial lines up with a apature reading but does not change when changing the shutter dial.
I'll attempt to attach a few picture of the meter soon.
Thank you,
S Raff
The operation should be very simple though, so if it isn't then definitely something is wrong.
Thank you the help.
S Raff
sraff
Member
North Devon
Any thoughts?
Thank you
S Raff
