cleaning sensor and focussing screen on DS
Posted 13/05/2006 - 19:23
Giottos Rocket blower available from the ephotozine sister site for only £6.99 incl postage (to UK I guess) at http://www.ephotozine.com/shop/cat_21_24.html
Posted 19/05/2006 - 23:48
any other suggestions?
Posted 29/05/2006 - 22:52
i got the kit using eclipse, pec pads, and a wand from micro-tools delivered for about 23USD. it works very well.. i like to mount my DS on a tripod to do the cleaning..
roy
roy
Posted 30/05/2006 - 14:00
I've used this with good results http://www.warehouseexpress.com/index.cfm?PHOTO/cleaning/visibledust.html Bit expensive though.
Posted 30/05/2006 - 14:12
I've used Eclipse and PecPads in the past... but I still had traces of stuff (especially when using a pin hole - don't ask!).
So I switched to DSLRclean from http://www.intemos.com/
I have the fluid too, and the CCD was so yucky I had to do it twice - wet, dry, wet, dry.
Now it's good
Now it's good
Posted 30/05/2006 - 20:34
DSLRclean is a dry only system from what I see on their website? You immerse the foam sticks in the liquid?So I switched to DSLRclean from http://www.intemos.com/
Are these foam sticks anything special? I know someone who buys them in bulk for use on high grade optics (he is a maintenance engineer on spectrometers).
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Posted 30/05/2006 - 20:50
Wet and Dry
Normally you use them dry - they create a small vacuum because of the design on the fibres, and effectively "suck" up the dust. That works great for most of the grime.
However, any organic or oily stuff needs the fluid - you just put a couple of drops on the bud, clean and then follow with the dry bud.
You never can tell from the hype, but I was recommended these by a couple of pros who have tried other systems. And I found they worked really well
Posted 31/05/2006 - 07:55
the price is allso reasonable compared to other systems.
For the first cleaning I think a wet cleaning has to be done? I don't believe it is 100% clean out of the factory.
Allthough I might wait a little while before cleaning it. The amount of specks is very small and starts to be visible beyond f/11 when shooting a light background (overcast or clear blue sky).
And since I will be going on holiday in about 5 weeks I do not want risk having to send the body in for repair...
Posted 31/05/2006 - 11:16
Posted 31/05/2006 - 12:10
They look pretty much the same - slightly "fluffy" texture to the buds. And when you apply them, the stick bends at the bud so the majority of the bud is in contact with the sensor.
Are they the bulk items?
Posted 31/05/2006 - 12:39
Yes, I have asked for the price. Maybe I can get a couple of these things. I could send you one or two so you can compare them.
Posted 16/06/2006 - 00:08
My biggest worry is that I might scratch the sensor.
Posted 16/06/2006 - 00:20
My opinion is don't clean the sensor unless you really have to. Over one year on neither Sue or myself have any need to clean the sensors on our *istDS bodies.
Posted 16/06/2006 - 04:09
sensor cleaning...
well as i understand it no-one actually is cleaning the sensor - what you actually clean is a piece of glass that protects the sensor.
So i thought i'd do a bit of a test, i got a piece of glass (old filter) and a piece of plastic (that should have far less scratch resistance than the glass) and i attacked them with some pec pads
first i cleaned them gently and carefully with the wet pec pads. Then i cleaned them pretty roughly with the pads.
Then i turned the pads round and stabbed at them with the handle of the pec pads.
I just about managed to mark the plastic, and left a couple of tiny marks on the glass. Which i then just rubbed off with a lens cloth.
So i decided that it's probably pretty safe to clean the sensor yourself as long as you are using proper swabs and not a scouring pad.
22 years
what is the safest way to clean the sensor (1 or 2 spots) and screen (quite a few specs)?
Kevin
