Circular Polarising Filter help.
Posted 01/05/2009 - 13:20
B+W and hoya make slim ring filters for wide angle lenses, not cheap though.
don't know of any "budget" filters that are thin.
Posted 01/05/2009 - 13:25
Is it "slim ring filters" that I have to ask for? Thanks
One way to keep the cost down is to look as a filter system such as Cokin P or Z system, then you will only need one filter to cover both sizes. The downside of the system is that you can't use your built in hood, however most systems do come with their own hoods as extras.
The other aspect to consider is how often you will use the filter. I have the Cokin P system with a Circular Polarising filter and it works very well on 52mm and 62mm. I am actually going to try it today on 77mm.
The Z system is larger and more suited to extrime wideangle. I will be testing at 16mm.
Just google 'Cokin'.
Flash: Metz 58, Metz 48
Posted 01/05/2009 - 14:21
Posted 01/05/2009 - 19:03
Ray, I wouldn't buy those to be honest.
The lens you will put it on cost a lot so it's worth to put a high quality filter on it or else you will most like degrade the quality of your photos, even those high grades do that.
Get B+W or Hoya, they are the best and worth the money.
I like B+W since the rings arent make of aluminium but of brass so they don't stick or get stuck like other filters do.
Posted 03/05/2009 - 19:47
Yes you can turn them, i believe all do to be honest.
It's worth to get the coated ones. i've a b+w pol mrc for my macro and it's on it 24/7 so the bit more protection and repelend against dirt and moist is welcome.
Posted 04/05/2009 - 07:10
Me wrote:
I vote for Hoya Pro1D, just ordered one (costs 38 Euro).
Laszlo
Do you have a link for this please. I vote for Hoya Pro1D, just ordered one (costs 38 Euro).
Laszlo
Thanks for all your help and advice.much appreciated.
Posted 05/05/2009 - 16:32
Laszlo
Laszlo
It seems they have only 52 and 58 mm at the moment
K20D, DA 18-55 II, DA 55-300, MC Zenitar K2.8/16, Tamron 24-135 3.5-5.6; Chinon CP-7m 35-70, 70-210; Optio 550; Olympus, Fuji
Posted 05/05/2009 - 18:07
"Agreed, B+W are superb filters"
Agreed. However, everyone forgets (or does not know) that HELIOPAN are just as good. Same Schott (Zeiss) glass, same brass mouns, same superb construction and materials and also German made.
Posted 05/05/2009 - 18:29
Yes, Heliopan as well, although we don't often see them around.
