Circular polariser and noise
Posted 19/10/2010 - 00:24
I'm using a Hama, Alan. And yes it's a cheapo. Quite disappointing really as I thought it would improve my photos.
Leon
K-x, K100D, DAL 18-55, DAL 50-200mm, Tamron 70-300Di, SMC M28/2.8
Posted 19/10/2010 - 00:55
leongu wrote:
First of all, forgive the ignorance but I've only recently used a circular polariser. What it is is that I've noticed increased noise in my photos whilst using a circular polariser. I would love to post and show sample images, but I'm not sure I can with no website to link the photos to.
2 of the photos I've taken have the following specs:
1. with cpolariser and more visible noise
24mm, f/22, 1/60s, ISO 200
2. no cpolariser less noise
50mm, f14, 1/200s, ISO 200
Appreciate if someone could advice if the use of a cpolariser has a direct impact to camera noise. I thought it was a bit odd to find noise at low ISOs especially on a K-x. Also note that the photos haven't been processed yet. So you can just imagine that noise would get worse post levels and contrast adjustments.
Thanks for your help.
f/22 with a polariser and 1/60 sec. Just how bight was it or were you covering arc welding?First of all, forgive the ignorance but I've only recently used a circular polariser. What it is is that I've noticed increased noise in my photos whilst using a circular polariser. I would love to post and show sample images, but I'm not sure I can with no website to link the photos to.
Some thing does not gel here.
Posted 19/10/2010 - 21:59
hahaha It wasn't quite arc welding Gary. I managed to link the sample photos and I hope it will make more sense.
1. shot with cpol
[IMG]http://i1209.photobucket.com/albums/cc400/leongu/samplewithcpol-noPP.jpg[/IMG]
2. shot with uv filter
[IMG]http://i1209.photobucket.com/albums/cc400/leongu/samplenocpol-noPP.jpg[/IMG]
1. shot with cpol
Leon
Posted 19/10/2010 - 23:10
Woh that's bit too technical Stefan, but I think I'm getting it now. So objective is to avoid underexposure which would lessen noise as well. I completely forgot that I lose 2 stops when using a polariser. Hence I should have compensated with an increase in f-stop or slow down shutter speed. I was shooting on Av mode and thought the camera was compensating on shutter speed automatically. Or did it?
Leon
Posted 19/10/2010 - 23:35
Yes it did compensate. The only thing here that I can think might influence noise is that the polariser has darkened some areas, as it should. Darker areas will show more noise.
Posted 20/10/2010 - 00:10
Thanks very much for the help and clarification John and Stefan! Good night!
Leon
Manchester
