Cheap remote shutter release
Pietrach
Posted 29/01/2010 - 13:29 Link
Hi
I am after remote shutter release. Did any one of you ever tried these cheap ones:
link
JohnX
Posted 29/01/2010 - 13:39 Link
Got one. Works fine But...
..if I were buying again (or in any event) I would look at buying one that offered a timer facility as well, but if all you want is to reduce the possibility of camera shake this will do the job.
Edited by JohnX: 29/01/2010 - 13:41
Pietrach
Posted 29/01/2010 - 14:14 Link
Thanks.
I might try one then. Anyway it is not a fortune
JohnX
Posted 29/01/2010 - 15:56 Link
You might also want to look at the Pentax Remote F. Little infra red jobby.
If you have a K20D, then it'll operate the camera from both in front and behind. There are also 3rd party devices that do the same job.
Deciding factor is whether you mind being tethered to the camera or not. The one you're looking at has a 1 metre lead (I think).
Gwyn
Posted 29/01/2010 - 16:21 Link
If you want a wired remote also look at ones suitable for Canon 400D/300D/30 etc.
I have this one: http://tinyurl.com/yzyhub3 from this Dutch shop. Free EU postage on it too. There are plenty of other shops around offering similar ones, OK a bit more than one from Hong Kong, but easier to send back if there's a problem.
I also have the remote F. I use that far more than the "tethered" remote.
bretti_kivi
Posted 29/01/2010 - 18:01 Link
... I made one for less than €5.
Same wiring as a Canon. Extendable, 'cos I used a 3.5mm socket not a fixed cable.
Bret
my pics: link
snappychappy
Posted 29/01/2010 - 18:44 Link
I use one which is very similar, works a treat.
bforbes
Posted 29/01/2010 - 18:56 Link
Same here. If you are looking for a bit longer reach, I added one of these, link
tomkeet
Posted 29/01/2010 - 19:10 Link
I have a similar one works fine, but I had to repair the cable.
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
promhandicam
Posted 29/01/2010 - 22:21 Link
I bought one like this which works fine and fits easily into a pocket in my camera bag. Works from both the front and back of my K10D.
Mongoose
Posted 30/01/2010 - 11:50 Link
for that price you can hardly go wrong. I use a Canon original wired remote which is rather better made than most of the generics I've seen while being a lot cheaper than the Pentax original. A good middle ground IMO.
but it does help
Edited by Mongoose: 30/01/2010 - 11:53
pink
Posted 30/01/2010 - 12:36 Link
I use a canon as well wired remote works well
I have a pentax F witch I have used on my k100D and K10D in the past put went back to the canon as the infrared was a bit of a hit and miss
Never used it on the K20D as I like the wired more anyway
James
bwlchmawr
Posted 30/01/2010 - 12:46 Link
I've had one for about a fortnight: works fine and is very well made, extraordinarily so, for the money.
I also bought a very cheap infra-red remote from China which is also effective but rather more flimsy.
Best wishes,
Robert Adams
Ernst Hass
