Changing from Analogue to Digital
Posted 09/06/2010 - 12:41
The K7 is a great camera. At the moment it's the flagship Pentax dSLR. The Pentax K-X is another option if you want to have good high-iso performance.
Other than that, your two lenses will work great on any dSLR. Just remember the crop factor though, so your 28-90 will be equivalent to a 42-135mm and the other is a 120-480mm on digital. That means you'll be lacking a lot on the wide end of things. You can pick up a 18-55mm kit lens on this forum from time to time for less than 50 quid though.
Welcome back to the forum!
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
Posted 09/06/2010 - 12:48
Lenses are covered.
FA lenses work without any problems or limitations, if you set the aperture on Auto.
the current DSLR don't support TTL flash however only P-TTL.
So will work but not in TTL only in Auto or Manual.
Hi and welcome, as above really, get some shots posted up when you can.
Posted 09/06/2010 - 12:49
Your flash might not work in auto mode on the newer DSLR, unless it also support P-TTL.
You should also verify the trigger voltage of the flash to make sure it won't fry the electronics on the new camera.
edit.: I hate it when Stefan types faster than me.
Posted 09/06/2010 - 12:51
Yves, Auto mode is something different then TTL or P-TTL.Your flash might not work in auto mode on the newer DSLR, unless it also support P-TTL.
TTL use the metering of the camera but Auto use a light sensitive sensor in the flash and use the information about aperture and ISO to calculate the right flash power.
Posted 09/06/2010 - 12:53
When I wrote auto mode, I meant P-TTL. Some old Pentax flashes don't have auto mode, if I remember correctly.
Posted 09/06/2010 - 15:17
I think SRS (amongst other places) have them new for £25.
Apparently.
Apparently.
Posted 09/06/2010 - 15:27
Yeah I know but it was confusing.When I wrote auto mode, I meant P-TTL. Some old Pentax flashes don't have auto mode, if I remember correctly.
For the voltage, any Pentax flash is good to be used if you've another brand of flash you need to be careful with some models but since you said the flash has TTL it's so good as safe, it's the older flashes that can give quite a voltage
Orpington
