Change lens or change body?
Posted 08/08/2007 - 23:30
The lens.
I'd much rather have the best lens on the worst body than vice-versa.
Of course, the best of both is ideal.
Posted 09/08/2007 - 07:36
At f8 the 18-55 is by no means bad, the vignetting at the corners on the wide end is a nuisance. The 16-45 is slightly better.
I see no reason to replace the body, apart from the fact that the K10D is a superb piece of kit. Lens dictate picture quality ultimately..
George! you make the K100 sound like a bad camera
Posted 09/08/2007 - 08:53
Phil
I'd say your best quality upgrade would be to add a fast-ish prime to complement your zoom lens. Something like a 50mm f1.7, or even f1.4, A series can be had pretty cheap off the auction site and seem to come up all the time. OK, you won't have autofocus but you will keep all your exposure modes. If you must have autofocus, even the F or FA series are not that pricy. And if you don't like it, you can always re sell it.
If you want to improve image quality, whether you're on a budget or not, primes are definitely the way to go.
Adrian
Adrian
Posted 09/08/2007 - 18:27
as yourself this question:
Why do I need to upgrade?
what is wrong with your current system as far as you are concerned?
what shots are you yerning to get which the K100D + 18-55 can't give you?
If you can't answer this question then I would suggest that you do not need to upgrade anything. If you can, then the answer will probably lead to which component is holding you back.
feel free to post the answer here and we will help you as to what you can do about it.
but it does help
but it does help
Posted 10/08/2007 - 10:49
Many thanks for your views, which have sorted me out! My problems lie with wide end of the 18-55, i've found that it can't be used less than 20mm because of the edge sharpness issues. I use wide angle most and I reckon that the 16mm of the 16-45 lens will be the bees knees!
Posted 10/08/2007 - 15:34
You will find that if you upgrade to the K10D kit it's got the same 18.55 lens so if it's lens quality you want then stick to the K100 and get the
16-45. If it's the camera you want then so be it, the K10D works well the 18-55. try it out and upgrade latter. I am.
