catch in focus with M lenses
chrissinkpen
Posted 19/09/2010 - 23:17 Link
I'm sure that I have used non 'A' lenses before.
Could someone jog my memory please, can't get it to work on my K200D.
Chris
Posted 19/09/2010 - 23:26 Link
You need to activate the custom function "using aperture ring" and set it to "permitted" after which you can use the camera in manual mode or Av with stop-down metering.
Catch-in or trap focus is where there is a manual focus lens used and the camera is set to AF. The shutter will only release when the camera thinks it is in focus - that is, when the green hexagon in the viewfinder stabilises.
chrissinkpen
Posted 19/09/2010 - 23:34 Link
Thanks John.
Indeed, it needs to be in AV mode.
regards
Chris
petrochemist
Posted 20/09/2010 - 00:03 Link
Not quite, M & B modes also work.
pschlute
Posted 20/09/2010 - 02:08 Link
chrissinkpen wrote:
Thanks John.
regards
Chris
Nothing to do with focus, but.....
You will only get pictures taken at max aperture in Av mode, irrespective of where you have turned the aperture ring to. You need M mode to use stop-down metering.
Edited by pschlute: 20/09/2010 - 02:09
