Catch In Focus - A Success!
I agree it's really useful.
Cheers,
Jon
Jon
Some occasional random stuff at The Photographers Block: link
So when did this "catch in focus" feature start ?is it on the K10 ? 'cos I don't think it's on the K100..jeff...
Mount a MF lens, set the camera to AF.S, hold down the shutter release and it wont go off until something hits the plane of focus.
As far as I know the only Pentax auto focus camera which doesn't have this is the ME-F
Brilliant shots both, I tend to use this feature for hand held Macro with my Tamron 90mm on the K-10D
but it does help
So with this method you are sure to catch a few spot on - I like it in 'burst' mode for this reason. The point of activation of the shutter is not always totally precise, and when there is subject movement also it makes sense then to fire off quite a few.
I actually found it useful with the 14mm lens as well. It can often be impossible to eyeball the focus point with this focal length, so the Catch in Focus works nicely too, especially for shooting at the widest aperture.
McGregNi
Member
Surrey, England
I believe the traditional application for this is when you 'pre-focus' a lens in manual, say over a birds nest for example, then trigger the shutter and wait - when something (eg baby birds) pass into the plane of focus it triggers the shutter.
Well on our Pentax DSLRs is also works with a manual focus lens in a different way. You start slightly out of focus and then turn the focus ring as you move the centre focus point onto your subject - when that point is in focus the centre focus light flashes and the camera fires.
It works a treat in continuous Hi-speed burst mode, especially with moving subjects when you can catch a burst of shots which may have slightly different focus points.
You just make sure that even though you're using manual focus you keep the focus mode selector on AF-S - this allows the autofocus system to keep finding focus for you and trigger the camera when it happens.
Heres a couple of shots I got using the technique recently - both with the K7 & Tamron Adaptal 135mm f2.8 (a lens from the 1970s!)
Thoroughly recommend anyone to try it out if you have a compatable camera!
