card capacity
Posted 04/07/2006 - 19:24
Hi Ken,
can't help.. sorry. I just had a look at the specs of each, and the only thing I can come up with is that the S50 uses 12 bit jpeg, and the DS uses 2.21 exif. I was looking to see if the S50 used 16 bit and the DS 12 bit, which may have explained it, but that didn't work.
I think this is one for Matt, or one the other techies here.
Liam
Liam
Liam
Posted 05/07/2006 - 05:42
JPGs are funny old things
You have to remember that the size of a JPG file is more related to visual frequency than pixel count. The more high frequency information, the larger the JPG. Added to that is the "quality" of the JPG save - a higher quality will retain more of that high frequency information.
My guess is this:
1. The CCD on the *ist-DS is much cleaner. All compact digicams produce a ton of noise in comparison. Image noise = high frequency which bloats the size of the JPG
2. It is likely that the S50 will tend to oversharpen in comparison to the *ist-DS, and again this increases the high frequency components
3. The image count is only a guide. Actual number of shots depends on the nature of the image
4. Not sure if there's a way to work out what quality setting was used for the JPG creation. The S50 and *ist-DS have completely different operating firmware, and you can't quite tell what setting they're using. The choices available in the camera settings are usually quite "coarse", but the JPG algorithms allow a very fine degree of tuning (like when you save under Photoshop).
There are lots of articles on the web about JPG that I could dig up to explain it all. Let me know if you need any
My guess is this:
Posted 06/07/2006 - 20:04
Thanks to both of you.
I'm quite happy to live without worrying about the intricacies of this!
20 years
Glasgow,
Scotland
1gb Sandisk card in *istDS shows a JPEG capacity of 334 images at 6mp
Same card in S50 shows a capacity of 309 images at 5mp.
Does anyone know why?
