Cable release for K5
Frogherder
Posted 18/01/2012 - 17:21 Link
Hi All,
Is the cable release for the K5 the same as that for the K10D.
I have a homemade one which provides focus and shutter via a small twin+earth jack plug
I also have a commercial one which provides timed/delay timed shutter release.
When I tried them on the K5 the focus didn't operate although the shutter did.
Bernard
Algernon
Posted 18/01/2012 - 17:48 Link
There's probably a setting in the camera menu to allow
AF with a remote, similar to the K20D
Frogherder
Posted 18/01/2012 - 18:08 Link
There is [C-18] and it's set to 2.
I have an IR remote which works correctly with this set, but not when set to 1.
I was wanting to use the digital timer remote to set up a series of shots, and whilst I can manually focus or use the AF button to do what I want I noticed the cable remote(s) wouldn't invoke a focus which suggests (to me at least) that maybe the pinouts are different, hence the question.
Bernard
Edited by Frogherder: 18/01/2012 - 18:08
Gwyn
Posted 18/01/2012 - 20:55 Link
I just tried my cable release in my K-5 and it auto-focusses just fine. I have a JJC which was meant for a Canon.
Algernon
Posted 18/01/2012 - 21:01 Link
Check the plug is wired like this:
http://www.doc-diy.net/photo/remote_pinout/
I'm offline now until tomorrow
Algernon
Posted 19/01/2012 - 09:10 Link
Just checked mine with the Pentax "CS-205 Cable Switch For Remote Shutter Release" and it focused first.... no problems.
Camera was on:
M exposure
NO SR (on tripod so I switched it off)
AF-S (GREEN)
Frogherder
Posted 19/01/2012 - 13:50 Link
Thanks all
Problem solved -
Both releases had a wire loose to the focusing
The plug end on the home built one
The switch connection on the commercial one.
And to cap it all I found the wire into one of the probes of my multimeter is intermittent.
What are the odds of that?
So soldering iron out and repairs done. Note to self - check thoroughly next time.
At least I didn't take the camera apart, then discover a loose wire in the multimeter.
Anyway thanks for checking. I didn't want to mess up my new camera, if the pin outs had have been different.
Bernard
Edited by Frogherder: 19/01/2012 - 13:51
Frogherder
Posted 19/01/2012 - 16:34 Link
Algi,
A most interesting site.
I rather like the multi-function trigger device based around the ATmega88V but have no facilties for programming it
regards
Bernard
Algernon
Posted 19/01/2012 - 16:57 Link
Glad to hear it was easy to sort out.
There is some interesting stuff on that site
