CA with 18-55mm kit lens
Posted 28/12/2007 - 09:17
Hello Allan, welcome to the forum. Can you do us a favour and post smaller images please, this is really big. to show detail you can post a small section at 800 pixels width.
As for the CA/fringing, it's not not too bad considering the subject. i have the k10 and 18-55 lens, this seems about normal.
Please call me aj,
Posted 28/12/2007 - 09:21
What you have shown is pretty demanding in terms of CA. On most subject matter you won't really notice it, but fine branches against sky can be a bit of a problem. It will also be less abvious when printed out at normal sizes. Enlarging images, especially taken at wide apertures, will show up lens defects.
The 18-55mm is a very respectable lens, but does need stopping down to get the best results. It is probably the best of all the kit lenses from any manufacturer.
Posted 28/12/2007 - 09:45
My apologies re size of file. Not sure what happened Imagecave normally cuts it down to size automatically. Will sort it out this am.
Posted 28/12/2007 - 10:50
It can. The one thing I find that makes PF a whole lot worse is when the twigs are against an overexposed sky, as they are in this case.fine branches against sky can be a bit of a problem.
One of the biggest culture shocks when I switched to digital from film was discovering that I had to expose for the highlights, not the shadows.
Now that I've got the hang of getting the sky exposure more or less right (most of the time), and boosting the shadows on the computer if there's a lot of contrast in the picture, I find PF a lot less troublesome.
Cardiff
Hopefully the problem shows in my attached shot. my question to you fellow kit lens owners is. Do i have a turkey of a lens that i should be discussing with Jessops or is this par for the course for a kit lens?
Hope to be a regular contributor to the forum which i have been following for months.Taken at f4.5
