Build yourself an ND Filter
Posted 02/09/2010 - 10:25
I can't help feeling an ND filter or two would be cheaper than two CPLs!
But if anyone would care to try it I'll be happy to see the results.
Posted 02/09/2010 - 10:28
If you're nervous about it you can buy these pre-built Just Google variable ND filter. Singh Ray do an expensive one, but there are also cheapo ebay ones around.
Tim
Posted 02/09/2010 - 16:59
If I may chime in, I tried this, but it depends amazingly on the quality of the PL filters as at maximum density, any colour cast of the filters becomes very amplified.
I spent about £70 on the PLs and still got a ruddy/brown cast. I changed it for two Tiffen Titanium 1.2 ND filters and get about the same density but zero cast.
C
C
Posted 02/09/2010 - 23:26
A more constructive(?) way to use 2 polarising filters is to place between 2 said filters an object of clear, moulded plastic. Contra-rotate the filters until cross-polarisation occurs.
Then will be revealed stress patterns formed within the object during the moulding process.
It's Fun!!
Below, an image of a circle-drawing template thus photographed.(with an LCD screen & 1 LINEAR polariser.)
Or use an LCD screen + polarising filter
Coker
It's Fun!!
Coker
Glasgow
link
Me coward and will not attempt
