Boost Lightroom Performance by Hacking the Lightroom Modules
mille19
Posted 26/09/2012 - 21:56 Link
Nice one, I don't know if LR is any faster but it is annoying having the book & map modules that I never use there all the time , now I don't have to.
mille19
Posted 26/09/2012 - 22:00 Link
Just found out you can do the same thing from within LR by right-clicking on the module toolbar and unticking the relevant boxes.
Smeggypants
Posted 26/09/2012 - 23:48 - Helpful Comment Link
The best way to speed up lightroom in my experience is to only enable NR and sharpening at the end of editing, just before export. NR and sharpening requires a lot of calculations to update every edit so it really slows things down in the develop module
Northgrain
Posted 27/09/2012 - 15:46 Link
That's (hopefully!) really helpful given LR4s sometime tendency for snailing.
How exactly do you change settings in LR for this??
Edited by Northgrain: 27/09/2012 - 15:47
Posted 27/09/2012 - 19:51 Link
I THINK the point is, if you just remove the buttons, the programs are still ticking over in the background. That's why you need to move the programs. I may well be wrong.
TonyM
Posted 27/09/2012 - 23:17 - Helpful Comment Link
No, you are correct.
mille19
Posted 27/09/2012 - 23:37 Link
I've tried both ways and didn't notice any difference.
Smeggypants
Posted 27/09/2012 - 23:51 Link
It's not a 'setting' as such but a workflow method.
Each section in the develop module can be turned on/off with the switch on the left handside of it's heading bar, if you want to apply an edit, and then 'mute' it
cabstar
Posted 28/09/2012 - 07:57 - Helpful Comment Link
If you have a dual hard drive set up then its usually best to pit your cache on the spare drive and increase it to around 50 gigs instead of the the default 10gigs. This speeds up LR considerably.
Concert photography
Northgrain
Posted 28/09/2012 - 08:00 Link
Thanks Smeggy- I get this now !
bettyswolloks
Posted 28/09/2012 - 12:37 - Helpful Comment Link
Never given the speed of LR much thought until this thread. Just set the cache to 20gig on a seperate hard drive and now its much faster It was only set to 1gig
Cheers cabstar
cabstar
Posted 28/09/2012 - 13:56 Link
Cheers cabstar
No worries
Concert photography
