Blur Images with kit lens
Spacus
Posted 03/05/2010 - 21:19 Link
Hi guys, I have been tusing a sigma 28-80mm, not the best of lenses but does get the job done firly. But recently I have been trying to use my kit lens for wide angle, but because of the movement and dancing around in my church I find out the closer images were all blur. I have a k10d and k100d super. I have taken a lot of advise here, and am using the k100d with the kit lens, please should I set it to sports mode as there is a lot of movements? the light at the church is not too good so am thinkng of rplacing the kit lens with a 16-45mm or a sigma 17-50mm. please i have a weeding aniverssary shoot in two weeks. I used a sigma 70-300mm on the k10d with a pentax af360fgz and i have some good close up's but obviously not a wide angle lens. Any sugestions.
K10d, k100d super, sigma 70-300mm, tamron 70-300mm,Pentax DA 18-55mm, simgma 28-80mm, pentax MF 1:2, 50mm, pentax DA 50-200mm.
Dangermouse
Posted 03/05/2010 - 21:31 - Helpful Comment Link
It sounds as though your problem is down to not having a high enough shutter speed to freeze the movement. Try putting the camera in shutter priority mode (Tv) and setting a higher ISO, when you adjust the shutter speed the camera will set an aperture to suit (quite possibly the widest aperture the lens can manage) so you can set the fastest shutter speed that the camera will allow. Alternatively if you're not quite ready to manage all the variables yourself then yes, set it to sport mode, but IIRC this doesn't allow you to change the white balance which most likely needs to be on "Tungsten" for indoor shots under artificial light.
When I photographed a stage show a few months ago I used an old 120mm prime at f2.8 and ISO 1600, which meant that the shutter speed was fast enough to shoot handheld providing I didn't try to catch people in mid-movement.
Spacus
Posted 03/05/2010 - 21:47 - Helpful Comment Link
thanks alot that's really helpful i will try it and let you know the out come.
thanks king
