Bigma and 1.4T/C
fatspider
Posted 09/07/2010 - 21:54 Link
Well I was the lucky one who was first to the post with the Sigma 1.4 T/C offered by redbusa99 (thanks Joseph it works a treat)
It arrived about 11am this morning and I was at the local RSPB reserve by 1.30pm, unfortunatly it was quite breezy but I managed to find a sheltered spot by one of the ponds, and yes I used the Bigma with the T/C to shoot macro
Anyone got any suggestions for stabilising a monopod? I'm normally OK at 500mm but pushing it to 700mm with the T/C is causing me some problems.
My PPG link
My Flckr link
Daniel Bridge
Posted 09/07/2010 - 22:49 Link
Add another 2 legs?
Dan
fatspider
Posted 09/07/2010 - 22:54 Link
Add another 2 legs?
Well I was thinking more on the lines of "grandma's secret recipe for stability"
but as you suggest a tripod can anyone reccomend a reasonably priced head for my Velbon CF (630 I think)
My PPG link
My Flckr link
beachboy2
Posted 10/07/2010 - 15:43 Link
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
fatspider
Posted 10/07/2010 - 23:01 Link
thats a good tip re-stopping vibration, I'll give it a whirl. I usually hold onto the tripod mount under the lens, maybe thats where I'm going wrong.
My PPG link
My Flckr link
Dangermouse
Posted 10/07/2010 - 23:19 Link
I've found a monopod works best if you think of yourself as the extra two legs. I tend to grip it and press down firmly with one hand, which reduces any tendency to wobble.
They are not as good as a tripod for long exposures - I use mine for distant subjects as it makes composing the shot a bit easier than attempting to hold a heavy zoom steady.
redbusa99
Posted 13/07/2010 - 10:58 Link
glad to see you are getting some use from it, just did not have compatible lenses for it.ENJOY
odd lens or 2
Mongoose
Posted 13/07/2010 - 12:42 Link
I'm sure you've realised this already, but make sure the SR is off as it will be working on the wrong focal length with the TC in place.
but it does help
fatspider
Posted 13/07/2010 - 18:22 Link
No I hadn't given it a thought, I assumed the T/C would automatically relay the increased focal length, just had a look at the exif on some of the pics I took and It would appear that is not the case
Turning SR off is going to be a bit of a pain, if I need it at 500mm I definately need it longer
Anyone know of a workaround?
My PPG link
My Flckr link
greynolds999
Posted 13/07/2010 - 20:51 Link
Only the most obvious suggestion - turn up the ISO to reduce the shutter speed!
pentaxanne
Posted 13/07/2010 - 23:05 Link
dont you mean increase the iso and shutter speed.
greynolds999
Posted 14/07/2010 - 18:01 Link
Just testing!
womble
Posted 15/07/2010 - 00:18 Link
Daniel Bridge wrote:
Add another 2 legs?
Dan
and a gimble mount?
