Big, strong, cheap, and light tripods?
Posted 26/12/2010 - 14:49
Is there any such thing as a big, strong, light and cheap tripod?
You were in with a chance up to the word cheap! Is there any such thing as a big, strong, light and cheap tripod?
http://www.ephotozine.com/article/3-Legged-Thing-X2-Eddie-Tripod-15244
Otherwise, perhaps the Manfrotto 055 Classic, but it's much heavier.
Posted 26/12/2010 - 15:02
Velbon sherpa range look good, I use the 200r although not with a 400mm lens.
Posted 26/12/2010 - 15:20
With a 400mm the head is more important than the tripod.
Posted 26/12/2010 - 15:31
Have a look at this one link as you can get it with a head at a special offer.
I am using it without any problems with a 5kg Video system and it comes with bag and if you get the special offer it is incl of the head.
Kind regards
SmutjeUK
It's nice to be nice!
SmutjeUK
Posted 26/12/2010 - 16:05
whelmed wrote:
Is there any such thing as a big, strong, light and cheap tripod? I'd like to get something that can support the tamron 400mm f4 which is 3kg with hood + my camera body as well. Any recommendations for something that would fit the bill?
Take a manfrotto super-clamp and a manfrotto or arca swiss ball head and clamp it to the roll bar on your 4x4?Is there any such thing as a big, strong, light and cheap tripod? I'd like to get something that can support the tamron 400mm f4 which is 3kg with hood + my camera body as well. Any recommendations for something that would fit the bill?
Posted 26/12/2010 - 17:08
I'll second the Red Snapper tripod. I'm about to order their ball head and a spare QR plate for mine (idea being I'll be able to leave one on the DSLR and swap the other around between film bodies), I've had the three section legs/head bundle for a month now and it's great.
Posted 27/12/2010 - 11:59
I have a Redsnapper RS-283 & RSH-528 Head plus a spare quick release plate, it's well made, not had a chance to really use it yet.
Colin
Edmund Burke (1729 – 1797)
Posted 28/12/2010 - 06:41
A set of Manfrotto 074B legs with geared column can be had from ebay for around the 30 quid mark, just about matches your requirements although I wouldn't want to go hiking far with them.
Brian.
Brian.
Posted 28/12/2010 - 11:30
Having trekked 2 miles in the snow fully kitted up with heavy lens and a tripod and head combo that weighs over 8kg on it's own yesterday, I spent several hours last night trawling the internet for advice from as many pro photographers as possible.
This is based on a 600mm lens combo though, so maybe a little overkill for your requirements, but good advice nonetheless:-
Get rid of the centre column. All this does at longer focal lengths is give you an extra weakness that will result in movement, therefore a less sharp shot. Even with a 6kg+ tripod and a 2kg head combo tightened up as much as possible, there was still camera shake from the mirror slap. Before anyone mentions mirror lock up, you can't use that tracking wildlife! This then leads into buying a tripod with no centre column, which normally leads you into looking at Gitzo systematic legs, which for a low weight (read carbon fibre) means looking at around £500. (£300 upwards for heavier aluminium ones)
As for the head, you should find that the Manfrotto 393 will be more than ample (£120 ish) for your 400mm. A wimberley MK2 (£500) would again probably be overkill for your 400mm, but is the ultimate for stability (and therefore sharp shots), and looks like it's the essential purchase for the F* 250-600mm that I just picked up.
Tripods are one of those items that you will eventually end up buying several of, because you will keep trying to get a better tripod, that's a bit more stable. It is best, from all the advice of everyone that actually uses long lenses for a living that I have found, to just buy the best now and get on with it. For me that means finding another £1000 (gulp!) if I want to get the very best out of my investment.
The main lesson that I have learned in the last week is that all of our tripods are not good enough (even a 6kg Manfrotto 058!) for ultimate stability. They maybe brilliant for landscape, macro or studio use, but carrying around all over the place for wildlife with long lenses just doesn't cut the mustard!
Will be putting up all our tripod gear for sale soon, as I now need to save up for a Gitzo!
This link helped me a lot last night. Good luck!
Posted 28/12/2010 - 12:37
I fully agree with Unlocker. I use the RedSnapper only because at the time I needed a quick fix for a tripod that will go down to ground level and that is all I use it for. As for my 'normal' tripod I use the Manfrotto 028 but I get more and more heads for it to use with different lenses. I am lucky to have a relatively light 500mm but with a 250-600mm I would have to get another tripod again.
The link is very good and plenty of good advise.
By now I use a 'Handy Garden Trolley', just the larger variety, to get all my gear about when I am out and about to 'shoot' wildlife in my area. It is a godsend as carrying everything would be to much for me.
The camera you buy is usually one of the smaller expenses. Its all the ad ons that you want/need that really eat up the money even if your camera cost over £1300!
Just think of a good camera bag and you quickly can spend £300+ for it, and that is just a bag!
Think how much 'Lightroom' or Adobe's 'CS 5' is. All of a sudden every camera is cheap, in relation to the bits you buy without noticing as you hardly ever give it as much thought as for the camera or an expensive lens.
Kind regards
SmutjeUK
SmutjeUK
You should go for the best you can afford. A tripod is not something to skimp on or you will end up buying several in attempt to get one that works, which will cost you far more in the long run than buying a good one to start with. look for one with the minimum number of leg pieces too - more leg pieces more chance of wobble.
Make sure the head is capable of carrying the weight plus some.
I have a Velbon Sherpa Pro CF 630, with a Markins ball head. I took out the centre column as soon as I got it, and have never used it, or needed it - the tripod is tall enough that I don't need it - nor does my husband who is is 6' 1".
I took my camera and Bigma to a shop and tried several tripods before opting for this one. It was without a doubt the most stable one in my price range. I tried a few Manfrotto models too but wasn't as happy with them. The combo, had I paid full price for the head, would have been the price of a new K10 kit at the time.
My only problem with it is it won't fit in a small suitcase when flying - you can't take tripods on board so it has to be checked - so I have to take a (too) big suitcase.
Posted 28/12/2010 - 13:34
If your "Big and Butch" a Leica wooden surveying tripod is much more stable than flimsy photographic wobly-pods and the feet can be pushed into the ground making it really rigid. Only £124 New ebay
Surveyors often carry several of these as well as heavy instruments such as Total Stations about for 8/9 hours a day along with a 14lb sledge hammer for knocking stakes in
Posted 28/12/2010 - 13:48
Manfrotto, Aluminium, £80.
http://www.jacobsdigital.co.uk/p-37827-jacobs-digital-manfrotto-mn190x-prob.aspx
whether its strong I don't know.
I'll keep humping my Benbo Mk1 around for now, although its seems heavier than it was 10 years ago.
Posted 28/12/2010 - 16:10
A 190B isn't very big compared to an 055; define the need in terms of height? A 055 with 222 head allows me to go over head height (and I'm not quite six foot tall) whereas I found the 190 too short.
A 161 is a nice way to do things; in the video studio I find 055 legs with a 501HDV head too light (!!).
Bret
Bret
my pics: link
