Bellows on a Q
screwdriver
Posted 02/12/2012 - 15:30 Link
Having seen how good the Q is at telephoto, I thought I would try the opposite, so I made a converter to fit a cheap set of bellows from a Q>D adapter, basically a thick washer, I used an old Takumar 55mm f2 for the lens
The reason I used a Q>D Type adapter is you can make the Q lens mount to M42mm lens mount distance below the 36.26mm (45.46mm - 9,2mm) with the bellows closed which means any 42mm lens will focus on infinity.
It's Winter here, but a few Lobelia flowers are still hanging on manfully
a few pics
The flower is 13mm across
Closer
Pop the flash up and back off a little
These are full frame, just re-sized for posting.
Chris
Edited by screwdriver: 02/12/2012 - 15:42
petrochemist
Posted 02/12/2012 - 15:58 Link
Even better than the telescope shots IMO.
I might find myself wanting a Q sometime
fritzthedog
Posted 02/12/2012 - 17:42 Link
Stunning - I lobe my Q and keep being surprised by it's capabilities
Carl
michaelblue
Posted 02/12/2012 - 18:06 Link
I'm continually pleasantly surprised by my little white Q.
I just wish the new zoom was a bit cheaper
Regards,
Michael
