Beautifull model under lights
McBrian
Posted 22/04/2006 - 23:07 Link
Turned my back for 1 minute and there he was.....posing.
Brian.
Posted 23/04/2006 - 00:27 Link
Love the third one!
Arthur Dent
Posted 23/04/2006 - 03:50 Link
Good catch! How'd you get him to stay still while you fiddled with the camera?
42 Comment Image
Mannesty
Posted 23/04/2006 - 09:08 Link
The last one almost looks as if he's smiling, I wonder why?
Cats, don't you just love em ?
I see you have all four bulbs now, any other interesting results yet?
McBrian
Posted 24/04/2006 - 21:35 Link
JohnRiley
Love the third one!
Thanks for the critique, I was quite pleased with that one too although I nearly messed up the whole shoot by leaving the 2sec mirror up setting on.
Arthur
He went and sat there on his own accord, sat for about 5 minutes even when I moved the lights around, just sat watching what I was doing. He loves lying on clothes (anything black), the velvet must have been too much to resist even though I had spent 10 minutes ironing and brushing it, even had time to change the lens and realise my mistake (see above).
Mannesty
No major surprises, they give off a definate blue cast but the auto WB seems to cope OK, I need to do more WB testing though. The one bad thing I have noticed if you put the lights close to a reflective surface it's like having 12 reflections, have to work on the diffusion a bit more, maybe get some opaque ABS parabolic discs made at work.
Presently working on MKII which I hope will look a bit more professional, using bosch aluminium profile.
Brian.
Posted 25/04/2006 - 09:34 Link
Great to see these Brian I suspect the cat imagined it was lying under the warm sun
Hint: If you want more diffusion, you must increase the distance between the light source and the diffuser
Mannesty
Posted 26/04/2006 - 23:39 Link
Brian,
are these goosenecks stiff enough to support an AF240FT flashgun weighing a tad under 300grams.
I want to make a high powered dual flash macro rig and I have everything I need except the means to fix them.
So far I have 2 each AF240FT + cable + hot shoe adapter, cold shoe to tripod adapter, small ball head (Hama). The ball head holds the cold shoe with flash and the other end has a normal female tripod mount.
If you think these are stiff enough to hold the gun in just about any fixed position, do you think it is simple enough to fit a male tripod mount into one end?
I started this project because I want a system that is useable in the field but powerful enough to use very small apertures to get max DOF. I realise this has probably all been done before . . . but I haven't done it yet, and I'd like to have a go. I did see the ideal solution on Ebay a while ago, a unit made by Novoflex but it sold for stupid money.
McBrian
Posted 27/04/2006 - 20:22 Link
Tied one of my AF360FGZ's (just over 300g with batteries) to the top of a gooseneck with a couple of these big red elastic bands that come with the post, it did support it quit well, I was actually surprised at how well it did.
Should not be a big problem to get some adaptors made to suit a standard male tripod thread (as long as you know someone with a lathe)
I got these ones from eBay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=29950&item=7400505775
Brian.
Mannesty
Posted 27/04/2006 - 21:07 Link
Thanks Brian. I ordered a couple of 200mm goosenecks and vases from a different supplier today. I though the short ones might support the weight better and I think 200mm + the ball head + the cold shoe + the flash would be long enough. They seem to be cheap as chips anyway so I don't mind wasting a couple if they don't work out.
