Auto Zoom Lenses???
Posted 20/07/2015 - 16:34
Hi Vic;,
Do you mean power zoom lenses or "automatic zoom lenses" ?
The power zooms were activated by a drive and didn't require you to rotate the zoom barrel manually to extend or retract the lens.
The recent photo on PU classifieds (below) shows a 28-105 power zoom, which I have (still) together with a 100-300 and they were decent lenses in their day for sure.
The zoom could be operated by a slight twist either way on the "scolloped" ring around the lens body which initiated the zoom extenstion/retraction
If an "automatic zoom" is something different I would be very interested to learn more about them.,
Kayling
Kayling
Posted 20/07/2015 - 16:49
I took Vic to mean the Powerzooms. Am I right that these are all designated 'FA J'?
Posted 20/07/2015 - 18:06
FA J lenses have no aperture rings and were introduced with the *ist film camera. They are not Power Zoom. These are designated FA.
Power Zoom lenses were:
28-70mm f/2.8
28-80mm f.3.5-4.7
70-200mm f/4-5.6
80-200mm f/2.8
100-300mm f/4-5.6
250-600mm f/5.6
28-70mm f/2.8
28-80mm f.3.5-4.7
70-200mm f/4-5.6
80-200mm f/2.8
100-300mm f/4-5.6
250-600mm f/5.6
Posted 20/07/2015 - 18:32
Thanks John ... Didn't know there were that many powerzooms either.
So, FA J's sound like they were the immediate precursors to the DA series , as in not having the aperture ring. Presumably the ist introduced a new contact in the mount to control the aperture? And I guess the istD continued with this, establishing the modern system we now have.
Is it this extra contact, allowing aperture control with no lens ring, that characterizes the KAF2 mount?
Posted 20/07/2015 - 20:10
Hi John,
In addition to your list, the 28-105 shown in the picture above in this thread is also a power zoom, designated SMC FA; it is a F4-F5.6.
I have that and the 100-300 too and they came out with the Pentax Z1P, being the same carbon grey colour as the Z1P; both were very respectable performers.
See link for powerzooms: https://www.dropbox.com/sh/3kn6tao5phmxen3/AACaOgKsqo9qcxS-gEDQYacIa?dl=0
DaronL
DaronL
28-70mm f/2.8
28-80mm f.3.5-4.7
70-200mm f/4-5.6
80-200mm f/2.8
100-300mm f/4-5.6
250-600mm f/5.6
28-70mm f/2.8
28-80mm f.3.5-4.7
70-200mm f/4-5.6
80-200mm f/2.8
100-300mm f/4-5.6
250-600mm f/5.6
Daronl
Posted 20/07/2015 - 23:32
The 28-70, 80-200 and 250-600 were FA* superb optically. My recent 28-70 FA* was a great buy...
The 28-105 was reputedly a decent performer, much better than later 28-105 variants.
The others were so-so in terms of performance. I had 2 28-80s, which were ok but irritated the hell out of me when the PZ function buttons fell off. They were replaced by the 24-90 which was superior.
AKA Welshwizard/PWynneJ
Posted 21/07/2015 - 08:15
Well now. That was all very interesting. YES I meant the power zooms. So what I gather from this is that they were FA. lenses and they weren't bad performers. I had a Z1p and also an *istD. These were my first Pentax SLR cameras (Unless you count my 645 as a SLR?) but at the time being new to Pentax I didn't know about the lenses to much. I se that according to JR the 250-600 was an FA lens. Was this made in both power and non power versions?
SO! If any came up cheap enough for my pension on the bay and they were a length I thought I might like would any of you say that they were worth buying?
If any of you have any idea of the worth of any of them then that might be nice to know.
CHEERS Vic.
CHEERS Vic.
Posted 21/07/2015 - 08:51
J.R. I just read your 2010 article on FA lenses. Very interesting. CHEERS Vic.
Posted 21/07/2015 - 09:58
I've read that too, in the magazine .pdf ... Very interesting and a good read !
Posted 22/07/2015 - 00:19
As has been mentioned, the PZ lenses were FA lenses and were the first K-AF2 lenses (i.e. using the additional PZ/SDM contacts at 5 o'clock on the mount). They were launched with the Z-1 & Z-10 bodies, the *ist was much later (after most of the MZ series). Optically they were all good (compared with contemporary zooms - some better than others) although the 28-80/3.5-4.7 seems to be slammed pretty hard in the US forum lens reviews - unfairly in my opinion (the original 28-105 was better though). I used to shoot Kodachrome 25 in my Z-1 using the 28-80/3.5-4.7 and apart from barrel distortion at the wide end - not much worse than my M28/2.8 - had little to complain about.
My review of the FA28-80/3.5-.7 is here: link
Build quality is a two sided affair - they're bulky & heavy due to the PZ motors, when in manual zoom the zoom collar is quite uneven in use and the focus rings also felt 'gritty' even when new. Apart from the zoom switch (which is a weak point on the cheaper lenses), they're robust lumps of glass. On a Z-1 the focus is slower and hunts more than an FA prime, although the K-5 drives them better. When they hit the end-stops when the AF hunts, they do so with a thwack. The AP/PP reviews of the time were mostly favourable.
Later FA (non-PZ) zooms (often silver) were given away in 'body+standard zoom' or 'body with standard & tele zoom' kits with the MZ bodies, but the FA PZ's were sold separately for the Z-1 & Z-10 bodies.
John.
John.
Posted 23/07/2015 - 21:09
The powerzooms were also capable of various zoom effects when paired with an appropriate body.
K.
Just found this info on the web:
1. Power Zoom
The zoom is motorized. The motor allows for three zooming speeds at a small twist of the zoom ring. The lens can also be zoomed manually by turning the zoom ring, a necessity with cameras that lack support for power zoom.
2. Lens Retraction
The zoom lens retracts to its shortest physical size when powered off.
3. Zoom Clip Mode
You can preset a focal length and you can then recall that focal length by pressing the zoom setting button on the lens.
4. Image Size Tracking Mode
You compose using the viewfinder so that an object (e.g. a child) fills the frame, say (a full body shot for example). When the object moves towards you or away from you the camera will zoom the lens so that the object maintains its image size.
5. Zoom Effect Mode
The lens will automatically zoom from wide angle to tele during exposure thus creating a special effect where the subject diffuses radially outward.
Which Camera Bodies Support Power Zoom?
All five modes are supported by the PZ series of film bodies.
K.
1. Power Zoom
2. Lens Retraction
3. Zoom Clip Mode
5. Zoom Effect Mode
Posted 23/07/2015 - 23:06
womble wrote:
3. Zoom Clip Mode
Depending on the camera you could store and toggle between two focal lengths (on the Z-1).3. Zoom Clip Mode
womble wrote:
5. Zoom Effect Mode
IIRC, the Z-1 could zoom either way depending on setting of a Pentax Function - note the shutter speed had to be within a certain range to get the best effect.5. Zoom Effect Mode
There was another zoom mode (at least on the Z-1), it was a 'portrait' mode which could be set for either 'head & shoulders' or 'full length' - set by a Pentax Function on the camera.
I don't think any of them were useful though, and they drained the (then expensive) Lithium batteries very quickly.
John.
Posted 25/07/2015 - 07:27
I'm glad I asked the question in the first place as it seems we've all learned something on this thread and the other one as well. However no one has come up with any answer to my question "What are they worth" I can't find any on the net anywhere so there are no guide lines there to go by. So come on all you wheeler dealers get your thinking hats on and give me at least a rough guide.
CHEERS Vic.
CHEERS Vic.
Posted 25/07/2015 - 07:48
A similar amount to any other lens of the same focal length. Most of the extra features won't work with modern DSLRs, although the power zoom will.
They are excellent lenses, but slightly more bulky than what we are used to.
Kettering Northants
I've never even seen one.
CHEERS Vic.
