Auto Takumars and Super Takumars
Posted 22/02/2011 - 20:22
What you have is recognised as a bit of an oddball - it's badged Auto Takumar but works like a Super Takumar. Not sure about that behaviour though, I've never had that lens or body. There is some research into problems with the lens here which might help.
Posted 22/02/2011 - 20:32
Info from the MFlenses guys seems to indicate that I indeed have a Auto-Tak labelled Super Tak. The S3 works with this lens (and my other Super Taks and S-M-C Taks) but the H2 requires the lens to be on manual for longer exposures.
Thanks Matt.
K.
Thanks Matt.
K.
Hertfordshire,
mostly.
The reason I ask is that I recently got an Auto Takumar 55mm f/1.8 lens (on a Pentax S3) but it works exactly like a Super Takumar. I read somewhere or other that the latest Auto-Takumars were actually Supers with the Auto name on them as they hadn't released the Super range.
I assume that when using a Super Tak on a Auto-Tak era body and using long exposures one would have to use the lens on manual? When checking out my H2 I found that the aperture closed down as one would expect but then opened straight back up again. Not a problem I would guess with a fast shutter speed but a bit of a disaster at 1 second!
Many thanks, Kris.
