Auto Focus Hocus Pocus
Posted 05/05/2012 - 15:03
k-5 menu section 5 button customization, shutter button half press, enable AF,
will do the trick,in the same sub menu AF button ,enables the AF button or Cancel AF
Posted 05/05/2012 - 19:31
Hi, thanks for the suggestion. The shutter-button-half-pressed enabled autofocus works fine with the other lens, and did work fine with the Tamron too - it's the only way I've ever focused. It's just that with no warning the Tamron lens suddenly started not to focus at focusing at shutter-button-half-pressed even though the shutter-button-half-pressed was enabled.k-5 menu section 5 button customization, shutter button half press, enable AF,
But I discovered that cancelling the autofocus at half press and as I say just using the back auto focus button works. Don't know what's happening there.
'my beauties' - Pentax DA55-300mm F4-5.8ED, Tamrom DiII SP AF17-50mm F/2.8 XR LD Aspherical (IF)
Posted 05/05/2012 - 20:36
i wonder then if you need to clean the contacts on that lens, i would check them against the other lenses you have as well to see if there ay difference...
Posted 06/05/2012 - 09:56
Thank you so much Caz. That seems the way forward. I'll finf out where the contacts are and check that on my return from holiday.
Posted 06/05/2012 - 19:47
The contacts are those little shiny bumps on the camera side of the lens mount, rub them vigorously with a lint free cloth, same goes for the corresponding contacts on the the camera body's mount
London
