Auto Chinon F/1.4 50mm - worth anything?
susanc
Posted 11/07/2007 - 14:22 Link
I acquired an Auto Chinon F/1.4 50mm was part of a job lot off eBay a while ago. I used it for a while but eventually invested in the FA 50mm F/1.4 which I love. It seemed to perform well but my dodgy eyesight is not up to manual focusing, especially not in low light.
Is it worth anything? Don't want to go to the hassle of selling it, if it's only worth buttons.
stevejcoe
Posted 11/07/2007 - 14:56 Link
I have no experience of this lens, my advice would be to check out the items on Ebay and make a judgement.
I just watched a Chinon CS4 with the same lens plus 3 others and a flash fail to sell at a £10 starting price.
That said if the lenses had been listed separately as PK fit the seller may well have had some takers.
In the end it is only worth what someone is prepared to pay for it
Posted 11/07/2007 - 15:05 Link
You'd sell a pentax manual focus 50mm f1.4 well enough, but I doubt that a Chinon would go for more than a fiver, if it went at all.
susanc
Posted 11/07/2007 - 15:12 Link
I'll probably put it back in a box and forget about it. Thanks for the info.
George Lazarette
Posted 11/07/2007 - 17:19 Link
At least try it. Most 50mm primes, whatever the manufacturer, are pretty good.
Posted 11/07/2007 - 17:22 Link
It's a reminder of what happens to second-hand values if the wrong name is on the front of a lens.....
Mongoose
Posted 11/07/2007 - 22:34 Link
If you want rid of it I'll give you the postage
but it does help
bretbysteve
Posted 12/07/2007 - 11:29 Link
...probably worth a small button...
Tyr
Posted 12/07/2007 - 11:39 Link
Chocolate buttons?
ibcsweb
Posted 03/03/2009 - 11:39 Link
I have a Chinon f1.7 Manual. I put it on my K10D and the camera will not take a shot in any of the modes, Tv Av Program, manual or anything. Any suggestions would be appreciated. I do not want to leave it in a cupboard as my wife bought it for me as a surprise while I was in hospital. She doesn't know anything about cameras just that I was looking for a 50mm f1.4/1.7 before the accident.
Pentax K10D 18-55 Kit Lens, Sigma 70-300, Photoshop CS (for now).
hefty1
Posted 03/03/2009 - 11:48 Link
Go into the "Custom" menu of the K10D and set "Use of Aperture Ring" to "Permitted".
Now you can use the aperture ring to shoot with, however, there are a few handling points to note:
1) In manual mode you meter by pressing the green button after setting the aperture on the lens.
2) In Av mode the lens will always be wide open (f/1.7).
3) No other modes will work properly.
4) The aperture value will always show in the viewfinder (and EXIF data) as "F--". This is because there's no electrical connection between camera and lens so the camera won't know what aperture value you've set.
5) When you switch the camera on it will ask you to confrm the focal length of the lens; scroll to "50" and press the OK button. Once you've done this once the camera will remember the last setting used so you can just ignore the prompt in future (unless you buy more MF lenses and change between them regularly obviously). This is for the shake reduction.
6) Enjoy your lens! Chinon 50's are usually capable of very good results.
Joining the Q
shim
Posted 03/03/2009 - 12:17 Link
These were very sharp in the centre (possibly better than the Pentax f/1.4) falling off considerably towards the edge. Not sure what the Bokeh is like, but it would be worth trying wide open on something like some flowers.
shim
iceblinker
Posted 03/03/2009 - 12:33 Link
An Auto Chinon 55mm f1.4 M42 recently sold on Fleabay for £36.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230327488636
~Pete
