Asphalt cracks
Posted 07/01/2020 - 08:27
Well composed and developed studies, certainly worthy of further study. I also think No.1 works well as a vertical image, the crack coming from the top.
Posted 07/01/2020 - 13:17
Great set Serge... really well seen and a great idea... even though it's asphalt, they fell quite organic... plenty of echoes of the natural world to these (presumably because at least some of them are caused by tree roots underneath?)... almost like a plaster cast... good luck with the series... plenty to explore I reckon...
Best
Best
Posted 07/01/2020 - 13:28
The lack of scale is what makes them for me. They could be mm, cm or furlongs wide! Very nice.
Posted 07/01/2020 - 14:26
I can see these as a set hanging on a wall of a waiting room or coffee shop. Really well seen and processed
Posted 07/01/2020 - 17:47
Thank you all for commenting.
John, yes they could indeed be planets, I hadn't seen that, so thanks (someone today told me some of them looked like cakes baking in the oven).
Nigel, it does work well, or better, thanks for the tip:
Bill, they are definitely the work of tree roots (and the morning light was helpful too, might I add). Will be keeping an eye out for more.
Agreed, Ben, lack of scale promotes mystery, which is always a good thing, for me.
Cheers Gareth, hopefully they will end up hanging somewhere.
Posted 08/01/2020 - 01:37
Excellent use of 'hanging about' time. They are fascinating.
Posted 08/01/2020 - 06:29
A different approach of subject matter that works. If you mentally remove the grass/plant debris from image #4, then image #3 & #4 also could have been mono images of the top of a cake?
Well thought out subject.
Posted 08/01/2020 - 12:07
Thanks David and Gary. Gary, yes that has indeed been suggested to me, and I concur.
Posted 12/01/2020 - 16:19
Thank you Peter, It will become an ongoing series, I'm sure.
Posted 12/01/2020 - 17:27
Great spot and nicely done.
Posted 12/01/2020 - 20:09
Cheers, Kris.
8 years
1
2
3
4
5
