Aputure Trigmaster ii on K3
balsembi
Posted 09/09/2014 - 16:52 Link
hi all,
just upgraded to a pentax K3 from a Kr
must say, what a camera it is....very delighted is an understatement.
I am getting ready for an adventure on the weekend and would really appreciate your help.
I have the aputure trigmaster ii transmitter and receiver to use with wireless flash and shutter release.
the problem I have is it works fine with the flash (transmitter on hot shoe) but when I try to put the receiver on the hot shoe for wireless shutter release it doesn't work. I connected the lead to the mic? I think this maybe wrong. the lights on the units are corresponding so they are paired up.
any ideas please?
need to get this sorted to take selfies!
many thanks
bal
Pentax K3 Pentax SMC-FA 50mm 1.4
Pentax Kr Pentax SMC D FA 100mm F2.8 Macro
SMC DAL 18-55mm Pentax SMC DA 18-270mm F3.5-6.3
SMC DAL 55-300mm Pentax DA 15mm HD F4ED AL
SMC Pentax-M 1:2.8 28mm
Darkmunk
Posted 09/09/2014 - 16:54 Link
Put the lead in the remote release cable port.
I don't have a K3 but it's down on the right, under the rubber flap I think.
Edited by Darkmunk: 09/09/2014 - 16:55
Algernon
Posted 09/09/2014 - 17:12 Link
Didn't the K-3 Blow-Up!!!
balsembi
Posted 09/09/2014 - 20:04 Link
haha, hasn't blown up yet
the lead supplied does not fit into that port on the k3. any ideas?
thanks by the way
Algernon
Posted 09/09/2014 - 20:21 Link
You need the correct lead, which has the same jackplug on it
as some Canons. 2.5mm diam. x 11mm projection.
You might have to buy the full unit again or possibly solder
a jackplug on.
IR is the other alternative.
McBrian
Posted 09/09/2014 - 20:40 Link
You need one of these, as long as the jack on your Trigmaster is 3.5mm.
Brian.
davidstorm
Posted 09/09/2014 - 20:48 Link
You need to buy a cable from ebay, they are very cheap, approx. £2 if from China and have 2.5mm plugs, not 3.5mm ones. They work perfectly, I use my Trigmaster II with these on both the K-3 and K-5IIs with no issues.
The link provided by Brian above is not correct, that cable will not fit as the plugs are too large. If necessary I have a spare cable you could buy, it cost me approx. £2, but you should be able to find one on ebay with no problems.
Edited by davidstorm: 09/09/2014 - 20:56
balsembi
Posted 09/09/2014 - 21:54 Link
thanks very much David, I have a lead like Brian has suggested and as you said, the one plug is too large.
thanks again, i'll take a look now
k3 is a beast.....love it
bal
