Anti-Shake on tripod
amoringello
Posted 20/12/2009 - 19:16 Link
I know it has been covered before, and with some degree of depth... but I found this interesting.
I took the following two photos; on a tripod, 2 second timer and no wind, bumps, etc... all things equal other than the anti-shake being on or off. I reproduced the effect multiple times.... oddly I have never seen this before thought I know some people here have mentioned that they had.
Anyway, the first is with Anti-shake on, the second is with it turned off. Even in these small versions you can see a significant difference.
pink
Posted 20/12/2009 - 19:39 Link
O'my god
That's it tripod no A/S
James
My Fluidr
Edited by pink: 20/12/2009 - 19:41
iceblinker
Posted 20/12/2009 - 19:46 Link
Shake Reduction is automatically turned off when using the 2 Second Timer, so the difference in the images is due to something else.
~Pete
Edited by iceblinker: 20/12/2009 - 19:47
Anvh
Posted 20/12/2009 - 20:01 Link
Yes indeed, strange
Stefan
K10D, K5
AF-540FGZ
amoringello
Posted 20/12/2009 - 20:08 Link
Hmmm you're right... I wonder if I did have the 2 second timer on for this one. I may have switched over after that. Probably my stupid lack of memory.
Although I am quite sure that I had turned the 2 second timer on because I thought I was possibly moving the camera while hitting the shutter. Yet the behavior did not change.
Perhaps the shake reduction does not always turn off with the 2 second delay? (i.e. time for a camera repair? i.e. time to upgrade to K7! )
Anvh
Posted 20/12/2009 - 20:12 Link
You can check if shake reduction was on or not with photome.
Already tried it with these but the that info is gone so you need to check it with the original file.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 20/12/2009 - 20:13
amoringello
Posted 20/12/2009 - 20:20 Link
Well, the shake reduction settings are DEFINITELY correct.
But as far as 2 second delay, I am only "pretty sure" that was true.
Anvh
Posted 20/12/2009 - 20:25 Link
I'm not saying that.
With the Exif data with your photos it shows the status how the SR was on that time, it does not look at your settings if you have set it on or not, it simply shows if the SR was active or not.
Stefan
K10D, K5
AF-540FGZ
amoringello
Posted 20/12/2009 - 20:40 Link
Ah... I suppose I could have taken the photo before SR was actually active, eh?
I wasn't looking through the lens at the time so it is certainly a possibility.
Now that I moved to a Mac I do not have access to PhotoME. It will give me a good excuse to get it installed on the VM and see what it has to say.
Bill_And
Posted 21/12/2009 - 20:24 Link
im pretty sure that the manual advises SR off for long exposures
must head off and look myself
Smeggypants
Posted 24/12/2009 - 03:08 Link
I tested the difference between SR and no SR on a tripod a couple of weeks ago and there was no difference whatsoever.
Posted 24/12/2009 - 08:24 Link
It will depend on the shutter speed, but in any event if you use the 2 second delayed action to avoid shake then SR is switched off by the camera.
Also bear in mind that SR is less effective at close distances, so the best results will be obtained with SR off.
As this will vary with shutter speed and distance, it's probably better to believe the advice given by Pentax and switch SR off when using a tripod.
