An experiment with a heritage lens
Posted 03/07/2018 - 15:33
If that was handheld, then that may be the reason for the softness at those extremes, worth trying again mounted on a tripod perhaps if poss
Chris
Posted 03/07/2018 - 16:38
Because of the weight of the camera, lens and flashgun, I used a monopod for the shot, but thanks for the advice
Posted 03/07/2018 - 17:19
Good stuff, it still might have not been enough support thou at your shutter speed of 1/180th sec even at 800 ISO
Chris
Posted 04/07/2018 - 16:02
It is still very much work in progress, part of the experiment was to try out the diy flash extender, with the x2 rear converter added to provide a ridiculously long focal length of about 1800mm (with crop factor). A tripod would have helped except that there was limited space in the viewpoint, hence the monopod approach. I am hoping to try the set up in the field on Friday. Fingers crossed
