An early heads up for a solar eclipse
Posted 24/02/2015 - 18:10
Cheers Gwyn.
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
K-1ii,K-3iii's.
Posted 26/02/2015 - 20:15
Thanks Gwyn, looks like it could be fairly good round here (84% max) - won't have the magic of Totality but I doubt I'll get to experience that again
Darker shades (13 or 14) of welding glass make it safe to observe/photograph & are available on-line at reasonable prices.
Posted 17/03/2015 - 07:13
Sadly it looks like it will rain on Friday here.
I am keeping my fingers crossed it is clear in the morning but it is not looking good.
That will teach me to fork out on solar filter foil to make my own filter and think I might be able to photograph it.
Posted 17/03/2015 - 09:18
It's 1999 all over again
Must admit 3 or 4 times I nearly purchased a solar eclipse filter but then went off to do something else ... maybe I saved some money for once.
Or maybe, knowing my luck it will be bright and sunny that precise moment and everyone will know who to thank.
Posted 17/03/2015 - 09:33
I bought foil from Amazon. Came from Israel and only took a couple of days to get here, it cost about 14 pounds for an 8"x 8'sheet . I have made a filter using an old uv filter and a ring with the foil sandwiched in between.
I have enough foil left to make a filter from cardboard for the Bigma (since I don't have any filters big enough for it), but I am holding off until nearer the day.
We did see the 1999 one, though it was not as full an eclipse as the one of Friday will be from here. Oddly my mother-in-law, who was staying with us at the time, preferred to watch it on the telly inside rather than in real life outside, even though we had eclipse glasses and I had set up a pin-hole viewer. Ah well.
Posted 17/03/2015 - 21:19
Some guides have said that a 10 stop ND should be good enough to get some good shots, using 100 iso, f/8 and fastest shutter speed as a starting point. Does this sound about right?
Pentax K-3, Pentax K-5.
Sigma 8-16mm f/4.5-5.6, Sigma 17-50mm f/2.8, Tamron 70-200mm f/2.8
Pentax DA 18-55mm f/3.5-5.6 WR, Pentax DA 55-300mm f/4.0-5.8
Pentax-A 50mm f/1.7, Pentax DA 50mm f/1.8, Pentax D-FA 100MM f/2.8 Macro WR, Pentax DA*300mm f/4.0
Posted 17/03/2015 - 21:42
Some filters can fracture under the intense sunlight, so I'd be very, very careful.
Posted 17/03/2015 - 21:46
No a 10ND is not safe for photographing the sun. You need a proper solar filter , or a home made one using filter foil.
Don't risk your the camera, or more importantly your eyesight!
Posted 17/03/2015 - 21:47
I observed the total eclipse from Northern France back in '99. To be honest getting any great photos is rather difficult without specialist equipment. My advice would be to enjoy the fleeting spectacle and forget about the photography,
Posted 17/03/2015 - 21:50
I shall give it a go if I can, but in the same way as photographing the aurora - camera on tripod all set up, remote in hand, me enjoying the show next to it. Wearing solar eclipse glasses of course.
20 years
The Netherlands
You can calculate the timings for where you are here (currently on Edinburgh but you can change the location.
Don't risk your eyesight or your camera though! There are lots of websites out there offering advice on how to get a photo if you want to try, but you do need a special filter.
