Allow use of aperture ring
mikew
Posted 30/07/2009 - 10:02 Link
I know this has been covered before but I read the posts and the manual and I'm still not sure of the answer so apologies in advance.
I have just bought a lensbaby and clearly it has no electrical contacts so I will set the exposure manually.
If I allow use of aperture ring on my K10D then the green button gets the exposure right.
If I leave it with that setting do I lose any functionality with my other lenses which are all Pentax DA etc. lenses.
Thank you
pschlute
Posted 30/07/2009 - 10:11 Link
You will not lose any functionality by leaving the setting to "permitted". I have mine set to "permitted" all the time.
mikew
Posted 30/07/2009 - 10:14 Link
That's the kind of answer I like - clear and exact.
Thank you.
ManixZero
Posted 30/07/2009 - 10:23 Link
To be honest I cannot help with the K10D but I have had this function enabled on my K100D since the day I bought the camera. (as I have a collection of Tamron Adaptall lenses and only a PK adapter)
I have not noticed any loss of functionality with "Modern A series or AF lenses at all.
I almost begs the question as to why the choice is there in the first place? (excuse my ignorance - those who may know why!)
And to be honest until I read your post I'd all but forgotten about the choice - I will however be leaving the use of the aperture ring ENABLED as I still use lenses without the contacts.....
MZ
K5, K7, Nikon FA.
AF Lenses: DA15mm Ltd, DA21mm Limited, DA35mmAL, DA50mm f1.8, DA18-55mmWR, FA28-70mm f4AL, DA50-200mmWR,Tamron SP70-200mm f2.8, AF70-300mm LD Di, SP10-24mm, SP90mm Macro.
MF Lenses: SMC-A 50mm, Adaptall 24mm(CW-24), 135mm(03B), 35-70mm(17A) 80-210mm(03A), Micro-Nikkor55mm, Soligor I-S 200mm f2.8 AIS
My Flickr - link
My Photobucket - link
mikew
Posted 30/07/2009 - 10:27 Link
I wondered why the option was there too.
I think it might be that if you inadvertently set the f stop using the ring on a modern lens then it will meter round that or something. Anyway thanks for the reassurance.
Posted 30/07/2009 - 11:16 Link
I've thought about this and the only thng I can think of is that it's to stop inexperienced users setting an aperture ring by mistake and getting very confused. If they try it, they can't take a picture, thus getting a positive warning that the aperture ring is off "A"
