Allow shutter release when focus not locked
photog 73
Posted 25/10/2007 - 03:48 Link
At times I would dearly like to release the shutter when focus sas been unable to lock. After all the depth of focus at moderate apertures can more than handle the small error.
I have read the manual and searched with Acrobat as well as the original Mark I human eyeball. I give up!
Can any one please help out?
Ron McDermott
Reformed large format photographer
Posted 25/10/2007 - 07:52 Link
I'll check the manual properly later, but why not use manual focusing in these circumstances. This is what the manual recommends on Page 65.
chirpy
Posted 25/10/2007 - 08:17 Link
You can also do that if you switch to the continuous focus option, though the risk of an out of focus image is much more likely.
Posted 25/10/2007 - 09:31 Link
Which camera???
If you're talking *ist-D/Ds/K10D etc then I have the following setup:
* In the custom menu, disable the AF-on-halfpress
* (For the K10D) make sure the custom function for the AF button is set to "Enable AF"
Then, you focus with your thumb by pressing the AF button on the back. (For the *ist-Ds it uses the OK button when you enable this mode). The shutter will always fire - even when it's out of focus.
Hope that helps!
SilverJON
Posted 05/02/2008 - 00:22 Link
Which camera???
Hope that helps!
Or, set it to "Disable AF", and hitting the appropriate button will disable the lock and let you shoot at any time.
On the K100D, it's the OK button in the middle of the D-pad.
