AF500FTZ not switching on
Posted 08/08/2013 - 08:34
Am assuming you have done the obvious - tried a different set of batteries?
Carl
Carl
Posted 08/08/2013 - 09:13
Get a finger into the battery compartment and rub the contacts. Try moving every switch many times.
It could just be atmospheric corrosion building up a film.
Posted 08/08/2013 - 09:48
batteries, check, contacts look clean...
no harm trying again...hoping someone in SW has the power pack which might help diagnosing.
cheers chaps.
cheers chaps.
AKA Welshwizard/PWynneJ
Posted 08/08/2013 - 11:07
Not on a flash but in the past I have had a problem with a device starting up following a period of being unused.
NiMH and NiCd rechargeables are nominally 1.2v whereas a Zinc/Carbon or Zinc/Manganese Dioxide (Alkaline) are 1.5 to 1.65v. So for a 4-celll configuration it is 4.8 compared to 6+ volts.
Try a set of fresh primary cells - the flash is designed to run with them and see if that is enough to kick it into life.
Posted 08/08/2013 - 11:57
Try the switch in the slave position.
Give it a few taps to make sure the batteries aren't
sticking.
Leave it on for about 5 mins, sometimes flashes are quiet
and can take a long time to charge up.
sticking.
Posted 08/08/2013 - 18:10
There's life
Slow to start but it's recharging quickly and it's on the rechargables
Thanks!
Thanks!
Richmond/Denbigh
