AF360FGZ
mitcho
Posted 19/11/2007 - 07:12 Link
Just a quick one. I am reading all the threads about this flash as I have just purchased one. I see most threads refer to the K10D. Can I take it that the K100DS will do the same as the K10D as far as operating with this flash? Can I use the advice given and use it for my K100DS?
Does that make sense????? I know what I am trying to say but my brain is not connected to my fingers!
Posted 19/11/2007 - 09:41 Link
You can use everything but wireless P-TTL flash
To do wireless P-TTL with the K100D, *ist-DS, K110D you need to have TWO AF360 flash guns - one as a master, one as a slave. Only the *ist-D and the K10D can use the pop-up flash as a wireless controller/master.
That said, you can use the "dumb slave" mode on the AF360 and trigger from the pop-up flash. Check out my guide to digital flash for the "how to"
All the other comments about exposure, manual mode, etc are all applicable.
Hope that helps!
mitcho
Posted 19/11/2007 - 09:56 Link
That does help, thanks.
I have printed out the sticky you did on this subject for a bit of light reading!!!!
