AF teleconverters
Posted 07/02/2007 - 15:18
Has Pentax released a 2x teleconverter that is compatible with AF lenses ?
No. Has Pentax released a 2x teleconverter that is compatible with AF lenses ?
There is an 1.7 one though.
Also there is a very good Kenko AF-Konverter 2x DG MC 7.
blende8
Lens-Buying-Enabler, retired
Admission executive of the "Kate IS/WAS/AND CONTINUES TO BE WONDERFUL" Nutters Club
Posted 07/02/2007 - 15:32
I think the 1.7 is an AF converter for MF lenses......and not a proper teleconverter....ARA wrote:
I'm sure someone will put me right
Posted 07/02/2007 - 15:35
The Pentax 1.7x AF converter can be used to convert manual focus lenses to autofocus.
However, you can just as easily use it with an autofocus lens - to some advantage! Because the focus is entirely inside the AF1.7x the lens never moves. You just manually set a rough position (say infinity) and the converter will do the rest.
In practise it works extremely well - I've used it with the SMC-F 70-210 and the SMC-FA 80-320
Posted 07/02/2007 - 16:38
One general problem with converters which wire all contacts is that you cannot set the correct (doubled) focal width for SR.
blende8
Posted 07/02/2007 - 16:40
Not a problem with the Pentax one
The body has absolutely no idea of the focal length - you have to manually enter it (which is a pain to work out 1.7x in your head).
Only snag is that it won't work so well for zooming...
Posted 07/02/2007 - 16:54
I really hope they put a manual override into the next firmware update, the teleconverter SR issue is really going to annoy me.
Posted 07/02/2007 - 17:14
With the 1.5 multiplier, tele-converters aren't quite so attractive as they were on film bodies.the next firmware update, the teleconverter SR issue is really going to annoy me.
Posted 07/02/2007 - 17:17
without SR they certainly aren't
Posted 07/02/2007 - 20:24
I did a few tests with a Pentax 1.7X and Sigma 2Z, my observations were posted in this thread...
https://www.pentaxuser.com/forum/viewtopic.php?t=3742
Brian.
Brian.
Posted 08/02/2007 - 19:03
I'm feeling slow today, SR is what ?
Posted 08/02/2007 - 19:36
Shake reduction
